i have been smelling oil and some coolant while i come to a stop there is no oil or coolant on the garage floor in the morning (2004 wrx) any ideas
Have you checked the oil and coolant levels? For how long have you smelled this? Was this immediately following heavy acceleration?
I experienced a similar smell in my old car after heavy acceleration, but it quickly dissipated. I'm pretty sure mine was caused by running rich after BOV actuation - do you have stock BPV?
My car has some oil smell when I park it in the garage. But I have no leaks. I have concluded it must be coming from the oil vapor that ends up in the intercooler thru PCV. I could be wrong. 1/2 quart in an oil change seems to be normal for me, and most of us with wrx's. Any coolant missing? That's something I would concerned about. Gettin any white smoke out the exhaust? Could mean head gasket.
I've got the same thing going on as well in my 2002 WRX. I am currently monitoring the fluid levels closely and am noticing no more than usual usage on either the oil or coolant. My plan is to replace both radiator caps(Mishimoto Radiator) to see if that affects the coolant smell. My oil issue is going to be a little more complex and will take a little more effort to take care of. Part of the issue I suspect is cam cover related, so I am replacing the cover gaskets along with the breather cover gaskets that sit on the cam covers. I am also going to go over the breather/PCV system and replace/clean anything that looks out of sorts. My biggest problem though is the fact that I had an oil filter go bad at the gasket some time ago spraying hot pressurized oil all over the passenger side of the exhaust manifold. This has taken Forever to burn off and I am convinced that the only way to remedy it is to remove all components and clean the hell out of them. All of this is waiting until spring when my warm weather cars can come back out to transport my happy ass around.
Might want to also check the cv axle boot. They will crack and sling a little grease on the DP. The valve cove r is a simple fix and can easily be done in an afternoon with time to spare.
