CAI in winter?
Discussion in 'Modifications And Maintenance' started by BrinkSTi, Aug 18, 2009.
  1. BrinkSTi
    BrinkSTi Well-Known Member
    I have the 65mm APS cai and i was wondering if that was something you should take off for the winter or if you can leave it on all year round. Also how often should you clean the filter? Thanks
  2. Nuke
    Unless your car is underneath 3 feet of water, I wouldn't worry about it.
  3. Tim the Plumber
    clean your filter with ever oil change
  4. mke723
    mke723 Well-Known Member
    ^^^^what he said, or sooner if you drive on dusty roads regularily
  5. WRX1
    And since it is the APS intake, I would also go back and check your fuel trims once it starts to get cold out (assuming you already tuned for the intake). I have seen the aps intakes throw off the afr a full point to the lean side.
  6. TickTack
    TickTack Well-Known Member
    Like everyone else pretty much said, you probably don't need to worry about it.
  7. BrinkSTi
    Yes it is tuned for the intake but how do you check your fuel trims to make sure its not running to lean in the winter?
  8. WRX1
    Any scan tool will be able to monitor your short term and long term fuel trims, and if those are getting maxed out, then you will need to adjust accordingly.
