Calling all BRZ/FRS owners!
Discussion in 'Modifications And Maintenance' started by Kneel Weiß, Apr 13, 2015.
  1. Kneel Weiß
    Kneel Weiß FUMP BDI
    Are any of you using a oil cooler? If so which are you using? I have heard and read the Mishimoto's like to set the car on fire or throw oil everywhere. Perrins ok but upwards of $600. Thoughts or ideas? I'll need one with the supercharger.
  2. EricS
    EricS Nooberator
    What about DIYing the Forester 2.0 DIT one?
  3. Kneel Weiß
    Kneel Weiß FUMP BDI
    no clue. Looking for options so I can hopefully get it done before the LAX cruise.
    Ryan FailRad and tangledupinblu like this.
  4. TMF
    I looked up the mishimoto kit and you're right, it does use banjo bolts on the thermostatic place. My sti kit doesnt...it just has - AN fittings and a couple 160 degree angle adapters. You might be about to buy the mishimoto kit and just use different - AN fittings and avoid the banjo connections.
  5. Kneel Weiß
    Kneel Weiß FUMP BDI
    I almost wonder if you could get an STI one and make it fit?
  6. TMF
    I think the unique part about the BRZ kit is going to be the mounting brackets. Unless you can weld, it's probably easier to get the BRZ kit with the right brackets and just forgo the banjo fittings and get the right -AN fittings...
  7. EricS
    EricS Nooberator
  8. Kneel Weiß
    Kneel Weiß FUMP BDI
    Thanks Eric!
  9. skubi1
    skubi1 Well-Known Member
  10. Kneel Weiß
    Kneel Weiß FUMP BDI
