Cam Lock ideas
Discussion in 'DIY Instructables' started by mn63, Apr 4, 2014.
  1. mn63
    mn63 Member
    I'm going to be doing the timing belt and such on a 2002 wrx. I'm looking to see what everybody else has done with locking the cams when replacing the timing belt. I'm not doing anything with the cam seals. I know Co. 23 makes a locking tool for like $50 plus shipping. I was hoping you guys would have another solution. The tricks I have used in the past wont work on a Subie.
    Any ideas, hints, tips would be welcomed.
    Thanks
  2. pbedroske
    pbedroske Well-Known Member
    I don't recall using any special tools (other than Blackozone) when doing my timing belt last summer.
  3. Curry
    Curry Well-Known Member
    Get a paint marker or crayon, mark the belt/cam/crank in two places for each cam and crank. Transfer the marks to the new belt, line up the new belt with the cams and crank and boo ya, Panda Express!
  4. RumblelikeaBoxer
    RumblelikeaBoxer Well-Known Member
  5. blackozone
    Lol, no. Check alignment marks when putting the new belt on. Job done.
    JasonoJordan likes this.
  6. blackozone
    Do your experiences come from a German background, by chance?
    pbedroske likes this.
  7. JasonoJordan
    Subaru has cam marks on each cam you just need to line up its very simple to do and no special tools needed.
  8. mn63
    mn63 Member
    No, My DOHC experiences has been with domestics. But the majority of my engine experience has been single cam, chain driven engines Chry 318's, Ford 351's, Chevy 350's, Chry (jeep) I-6's.
    I'm familiar with the timing marks on the cams. I got a taste of the Subaru timing belt system last summer when I did my sisters boyfriends Water Pump. But he has a Legacy Outback with a SOHC. I've seen You Tube clips of the DOHC belt replacement with out a "locking" device, Looks easy enough, but the engines were out on stands. Everything is easier when its out on a stand. I guess I'm paranoid about messing it up seeing as how its my DD, only mode of transportation and I don't have "new engine money" laying around. I'm not afraid to admit when it comes to Subaru's I'm a Newb.
    When I looked in to how its done on the WRX engine, Company 23's "cam lock" tool kept showing up so I think I just assumed you should lock the cams if you were not doing anything with them. For me doing anything with timing and interference engines gets me a bit nervous. It's not an every day thing I deal with. More so when its my only ride and x2 when theres more than 1 cam involved and I have minimal experience with that type of engine. If you guys are able to do this without an (OMG you NEED this stupidly expensive tool because you will seriously die without it, why because we said so now buy our stuff) Tool Then Im sure I can too.
  9. JasonoJordan
    im sure it helps keep things held in place while your routing the belt through all the various pulleys and the tensioner. I just had a extra set of hands when I did mine that helped but know plenty of people that have done it solo and when it was inside the car ontop of it. All in all would the tool be nice sure if you want to spend the money. Do you need it no.
  10. glen
    glen Well-Known Member
    A lock tool is handy for getting the pulley bolts loose, but you shouldn't have to do that just to change the timing belt.
  11. mn63
    mn63 Member
    Thanks all for the responses! I plan on tackling this Sunday, without spending money on an OMG you NEED this stupidly expensive tool because you will seriously die without it why because we said so now buy our stuff ........ Tool.
  12. blackozone
    Yeah, you'll do fine with just your basic hand-tool set.
  13. whitey
    whitey Well-Known Member
    Get yourself a 10 mm allen wrench to rotate and hold the cam gears in place. Have you pulled the timing cover off and taken a peek to see if any of the cam seals are leaking?
  14. mn63
    mn63 Member
    [Yup!E="whitey, post: 754624, member: 5156"]Get yourself a 10 mm allen wrench to rotate and hold the cam gears in place. Have you pulled the timing cover off and taken a peek to see if any of the cam seals are leaking?[/QUOTE]
    Yup! I looked everything over best I could including cam seals. All appears to be good. I wasnt able to swap stuff out today like I planned, but I'm hoping Thursday. I looked over the current belt and was kinda suprised how good it seems to be. No glazing or obvious cracks and the markings were still there.
  15. mn63
    mn63 Member
    GOT IT DONE!!! Thanks guys for the confidence of not needing fancy tools. It was Straight forward and not difficult for the most part. The two hardest parts were the crank bolt and my paranoia of making sure all the timing marks were perfect. Must have obsessed over it about a dozen times before pulling the tensioner pin.
    phi11 likes this.
  16. derp
    Next time weld it all together, it'll never move again
  17. mn63
    mn63 Member
    HA!!! Riiight...
  18. Todd
    Todd The Originator Staff Member
    I made my own cam holder for doing dual cam 2.5's...
