Can you review this picture if transmission has been worked on?
Discussion in 'Modifications And Maintenance' started by Le Ho, Aug 4, 2016.
  1. Le Ho
    Le Ho Active Member
    Hi People,
    I was thinking of not posting this so i deleted it. But you guys kept it up anyways. I guess i will post the picture anyways. I need your help.
    Thinking of buying this car. Can you review the bolts on this transmission. Does it look like it has been replaced? or the gasket been replaced? Should i be of concern? Or am I'm thinking too much. It is a 2008 Spec B. Thank you.
    Le
  2. idget
    Dunno but that paint markered "3" on the subframe makes it look like a junkyard replacement part.
    What part of that pic are you concerned about? The rust and the black soot?
    Good luck with your search/purchase, Le.
  3. Le Ho
    Le Ho Active Member
    Oh no. Your scaring me more idget! The black markings around the bolts of the transmission and black soot around it. Looks like the bolts been touched? Should i be worry about that? Should i be worry about the 3 now? haha It says clean title.
  4. jmyhre05
    jmyhre05 Well-Known Member
    These 6 speed a are pretty much bullet proof. If your concerned bring it to a Subaru specialist shop for a inspection. There are a couple, but if you want us to we don't charge too much.
    www.jmautomn.com
    www.facebook.com/jmautomn
    We're really booked up right now but just a inspection we can usually squeeze in without a problem.
  5. blackozone
    I don't get it, what is going on here?
  6. blackozone
    Rust on a Minnesota Subaru is like Coors in a trailer park. If you don't see it, something's up.
  7. Le Ho
    Le Ho Active Member
    The black markings on the bolts of the transmission with no rust, maybe it had been worked on. Im more concern with the #3 being a junkyard part. Is that #3 normal on a stock car? Thanks for the feedback.
  8. blackozone
    That car has definitely been in a flood.
  9. blackozone
    And I think the black markings are fire damage.
    The car was on fire during a flood.
  10. blackozone
    Butt seriously, I don't see an issue that would require too much worry.
    Have you asked the seller these questions? Usually that's the first place to start.
  11. Le Ho
    Le Ho Active Member
    Dam, guess the car is not the one.
  12. Le Ho
    Le Ho Active Member
    I did, he said its never been repaired to his knowledge. He is the 3rd owner. Clean title.
  13. blackozone
    Run a VIN check on it to confirm and have it inspected if you're that worried. I'm not entirely convinced the markings indicate a junkyard part.
    Are you looking to collect this car and preserve it?
  14. Le Ho
    Le Ho Active Member
    Thanks for your input. The carfax is clean. I will test drive and inspect. No i will daily drive it. Wish i could collect and preserve.
  15. blackozone
    Just don't make mountains out of molehills. Looks like JM Auto is willing to have a look at it for you for piece of mind.
  16. Nhibbs
    Nhibbs Well-Known Member
    Fireflood for sure. I wouldn't worry about the tranny. If it doesn't make funny diff noises when driving/turning sharp.
    But it has a turbo and a stock Subaru engine so it will definitely assplode very soon. Buy a corolla or Camry.
