car click when turning
Discussion in 'Modifications And Maintenance' started by that-dude, Apr 8, 2009.
  1. that-dude
    that-dude Well-Known Member
    my 91 t-leg click when turning. the clicking sounds seems to be coming from the strut area but im not that sure. its also hard when turning too. i check the power steering fluid and it still good. it will turn smooth then, click, harden up. any pionters will greatly help. thanks
  2. project/driven
    cv axle, or the rack is going bad...
  3. yangsTa
    yangsTa Well-Known Member
    Axles.
  4. that-dude
    yeah i was think those too, thanks
  5. Warthog
    Warthog Member
    ^this. If it is your CVs then the clicking will get worse/louder when you accelerate when turning. Check the boots on the CV, when they are bad the boot is usually shredded and there will be grease all over.
  6. esperunit
    esperunit Well-Known Member
    had that same problem also turn out to be simply a disconnected endlink where a bolt fell out. Put it up on jackstands, get a friend to steer it back and forth and take a look
  7. Snowbum
    Snowbum Well-Known Member
    I'm also thinking endlink/swaybar.
