Car dies when I fill it up?
Discussion in 'Modifications And Maintenance' started by 02WRX78, Aug 18, 2010.
  1. 02WRX78
    02WRX78 Active Member
    I am actaully posting this for a friend but whenever he fills up his tank in his I believe 2004 legacy the car dies when he starts it up to drive away, then it will do it every time he stops or isnt on the gas for the next couple of miles but then the car works perfectly fine after that. Could this be a fuel pump why does it do this?
  2. ortho004
    ortho004 Well-Known Member
    No idea on the problem, but is that cow from The Farm?
  3. Frogy
    Frogy Well-Known Member
    How many times does he try to fill the tank after the first time that the pump auto-shuts off?
  4. Lowrider
    Lowrider Well-Known Member
    LOL...That is a wild Buffalo
  5. kvang
    kvang Well-Known Member
    Is this the 1st time that it has occured, or does it happen everytime he fills up? If it is his first time. I seen a vehicle in my shop that had came in with slightly the same issue, there was bad gas/water in the gas at the gas station that he got it from. To check unhook fuel feed line and get an old water bottle and key on a couple of times into the bottle and watch the water seperate from the fuel. Water should be at the bottom as fuel is a lighter fluid.
  6. Ylime
    had this problem..something is wrong with the fuel sensor or regulator whatever its called..just needs to be replaced or is hooked up worng. not a majpr peoblem, I ran this way for a couple months.
  7. 02WRX78
    I think he just clicks off and calls it good
  8. 02WRX78
    no it happens everytime and the gas station he goes to is good
  9. 02WRX78
    alright we'll have to look into that thanks
  10. Ylime
    seriously not a huge deal..search on nasioc more info.
  11. issues
    issues Well-Known Member
    Check your gas cap and vac test your charcoal canister check for pending codes.
