Car won't start. 08 STi
Discussion in 'Modifications And Maintenance' started by tonyv, Feb 19, 2014.
  1. tonyv
    tonyv Well-Known Member
    So, I tried doing the DIY bluetooth mic for the 08 Nav head unit. I did a test on it two times to make sure it worked and everything seemed good to go. After i installed the panel back on; I tried to give the car a start and the Nav unit was loading. It stopped and flickered 3-4 times and the head unit went blank. I turned off the car and tried starting it without any luck. I took the head unit out to see if the car would start up without it and still no luck.
    When I turn the car on the car's electronics - speedometer gives a slight hesitation and the "ampg" only goes up slowly. When I try turning on my lights; only the right side would turn on and then turn off and the left side would turn on.
    Would this be a dead fuse or just something worse? It's a bit late and i wont be able to work on it until after work tomorrow.
    The car will only click when trying to start.
    Thanks for inputs
  2. DIRTY D
    DIRTY D Well-Known Member
    Check the fuse box in the front under the hood and see if you blew a fuse. Also thinking you have a good battery check the volts. You should have extra fuse in the front hood panel.
  3. tonyv
    That's what i'm thinking. Hopefully nothing to crazy. I'll take a look tomorrow after I get off work. This make me hesitant to plug the mic back in...
  4. DIRTY D
    sounds like you did not disconnect the battery when you did the install. or maybe a ground issue. good luck
  5. tonyv
    Yeah, i'm guilty the second time(after covering up the exposed wires) I just plugged everything in with battery connected.
  6. TMF
    I think I've left the battery connected before when installing radios...haven't had an issue that I recall.
    I don't mean to point out the obvious, but it sounds like you may have a dead battery. Did you try jumping it and/or checking the volts at the battery?
  7. tonyv
    I haven't tried giving it a jump since everything lighted up last night. I checked a couple of fuses in the car this morning before leaving to work - the ones labeled head unit and the ones next to it and they all appear to be good. I'll probably go buy a set of fuses once i'm off work and check the fuses in the engine after giving the battery a jump.
