car wont start stranded at rich's cabins
Discussion in 'Modifications And Maintenance' started by wrxpeed, Mar 2, 2008.
  1. RichWRX
    RichWRX Well-Known Member
    Put new plugs in today and there is no spark, I noticed the main fuse was blown so I changed that but still nada. I will tinker with it tomorrow and see if there is anything I can find
  2. Speedemon
    Speedemon Well-Known Member
    i would guess you have a short somewhere, you keep blowing fusing
  3. wrxpeed
    wrxpeed CobraPeed
    sweet, thanks rich. I owe you a ton.
    We thought that's what it was but it was just coincidence that the car started after we changed a fuse. The fuse we changed ended up being the cigarette lighter or something not related to the problem. I didn't notice any other fuses blown all weekend when I was checking them.
  4. RichWRX
    the fuse was under the dash, when I looked it up it said main fuse
  5. wrxpeed
    wrxpeed CobraPeed
    ohh ok. THe ones i looked at were on the panel inside the door. Do you have a scan tool to see what the CEL i had meant?
  6. RichWRX
    I have a obd2 scan tool, I dont think it will work on yours but I will check
  7. AspitFire
    no his car is obd1, iirc
  8. curly2k3
    this, gotta do the flashing trick
  9. Chux
  10. wrxpeed
    wrxpeed CobraPeed
    cool, if rich can't figure it out, which I don't blame him since electronic issues are a PITA, I may have to hire your services.
  11. RichWRX
    going out right now to check and see if there are any codes
  12. RichWRX
    here are the codes it pulled code 11,33,23,49
    11-crank angle sensorNo signal entered from crank angle sensor, but signal (corresponding to at least one rotation of the crank) entered from cam angle sensor
    23-Air flow sensorAbnormal voltage input entered from air flow sensorControls the amount of fuel (injected) in relation to engine speed and throttle sensor position
    33-Vehicle speed sensorAbnormal voltage input entered from vehicle speed sensorSets vehicle speed signal to a fixed value
    49-Air flow sensorUse of improper air flow sensor
    I just turned the key to the start position and these are what flashed on the cel light,
    from what i can figure out its probly the crank sensor.
    I also noticed that the keeper pin for your passenger side front axel way all the way out, I put it back in. The way it was your tire could not of been spinning. you was in 3 wheel drive :)
  13. Deride
    That would do it, and I know they go bad as my friend just replaced one on his tleg.
  14. RichWRX
    do you know how hard it is to replace it. if its not hard I can get one tomorrow and change it.
  15. RichWRX
    Just got back from a little ride in my new legacy SS :) :)
  16. AWDimprezaL
    MAN i am good
  17. RichWRX
    at what ;)
  18. AWDimprezaL
    diagnosing crank sensors
  19. RichWRX
    hes owes you some jag then :)
  20. tangledupinblu
    THIS!! 3rik rUlez you f00lz!
  21. Threshld1
    Threshld1 Well-Known Member
    My sisters car did this recently also with the same set of codes along with a coolant temp sensor code. Replaced that and it fired right up. If it hasent been done on this i would suggest just doing it, it does some funky things when they start going bad.
  22. phi11
    or absinthe!
  23. RichWRX
    Hopefully his car still runs when he comes up to the ice race next week ;)
  24. tangledupinblu
    I STILL have the aftertaste in my mouth.:eek3:
  25. StatGSR
    StatGSR Well-Known Member
    glad to hear its alive again!
  26. AWDimprezaL
    indeed the coolant temp sensor wacking out can cause a hard start, but it wont kill the spark.
  27. AWDimprezaL
    Thanks josh, apparently I don't do anything helpful around here :cough: taras :roll:
  28. tangledupinblu
    lullz.
    You were the first person to respond to Brian's thread(within 30 min.), and had it on your first guess.:laugh:
    /You owned this thread.
  29. driftin240
    driftin240 Well-Known Member
    Seems that lots of us were on the same (correct) track.
  30. carl
    that's what she said
    glad to hear the car is running!
  31. tangledupinblu
    Hahaha...3rik was just t3h fasttt0r.
    Brian, you're a genius too!:biggrin:
  32. curly2k3
    you sir are a nancy, i liked it.
  33. wrxpeed
    wrxpeed CobraPeed
    W00t! Absinthe for all! I'm pumped. Thanks for all the help guys, especially rich, you're a life saver. I owe you big time.
    I'll pm you when I get home. I'm posting from my blackberry and doing anything is a chore and pming on a blackberry sucks when it flakes out.
  34. piddster
    I've got spare crank and cam angle sensors for this reason. Mine could go bad since they have over 200k on them. I just don't want to spend $250 on a new new one. :eek4:
  35. AWDimprezaL
    you are high! cam and crank sensor kit is under 60 bucks, when was the last time you priced one?
  36. piddster
    wait, what?
    From 1stsubaruparts.com which is usually around what the club discount price is from you guys.
    Please tell me I'm way off base here.
    Edit:
    Shouldn't they be the same????? WTF!!!!!
  37. Chux
    ^that's crazy. why would the imp one be so much cheaper?!
    I'm curious if the t-leg was still running kyles fuel pump. the CAS definitely explains many of the symptoms, but not the fuel pump. or the fact that it was only even trying to come on some of the time.
    but, I'm glad to hear it's repaired.
  38. AWDimprezaL
    dont know why its like that, but they made this "kit" because of the older legacies
  39. AWDimprezaL
    i see where you are getting those, but we do sell the kit! doesnt make sense, pretty sure they are the same, being i am running one from a legacy in my car!
  40. Chux
    bump for reference.
    '92 legacy crank and cam sensors respectively:
    '96 imp:
    only difference appears to be the legacy ones have the wiring pigtail, and the imp ones have a plug on them. I bet you could snag the wiring connectors from a junkyard, and splice them onto the legacy pigtails, and run the muuuuch cheaper imp sensors.
  41. wrxpeed
    wrxpeed CobraPeed
    Good to know chux since I'll have to change them out soon. The car has been running like crap and am throwing CPS codes.
  42. piddster
    If you are going to splice something like that be careful. The two wires are twisted and also sheilded by a jacket, like coax. Is the plug on the back of the motor the same? One could use the whole impreza plug, or not. The wiring layout on imprezas is lame...
  43. Chux
    it's not the same. the wiring for the 2 sensors is intertwined into the engine harness. also, it looks like the wiring right at the sensor is not shielded, so I don't think it would be too hard to splice that plug on to the legacy wire. in fact, at a glance, the plug looks identical to the injector plugs.....
