Catch Can questions
Discussion in 'Modifications And Maintenance' started by svxninja, Oct 5, 2012.
  1. svxninja
    svxninja Well-Known Member
    So what do people do with their catch cans that have a breather on top? because if you leave the breathe on top there might be a chance the moist air might freeze in the breather? Currently I have mine where the stock air box would be
  2. svxninja
    Bump?
  3. issues
    issues Well-Known Member
    sell it and get a grimmspeed AOS?
  4. Nuke
    you're going to have some sort of moisture inside your engine. with the breather, you'll have more. but with a fully warm engine, and driving it for a bit, most of the moisture should evaporate.
    svxninja likes this.
  5. Tash
    Tash Well-Known Member
    So idk your setup but as far as I have seen, catch cans in the winter are not so great
  6. svxninja
    Is there another way around it? Last year I just put a 90 degree piece of pvc pipe on the top of the can facing the rear of the car
  7. tangledupinblu
    Grab a BMW catch can. They are heated.;)
  8. Tash
    So is the Perrin v2?
  9. TMF
    ha is that a joke, or are you for real? I suppose it makes sense if its on a BMW...
  10. tangledupinblu
    I am for serious! This is the internet after all, i wouldn't joke on the internet.
  11. TMF
    "do you believe everything you read on the internet?"
    "Yes, because everything on the internet is true!"
    "Where did you learn that, the internet?"
    "The internet!"
  12. tangledupinblu
    The internet cannot lie, it's against everything that the internet believes in. Also, gingers (Shibbs) does not lie either...ever
