Cel code
Discussion in 'Modifications And Maintenance' started by aj99civic, Jan 4, 2010.
  1. aj99civic
    aj99civic Member
    sorry this is from my other thread but i need you figure this out.. my cel just turned on this morning and i brought it into the shop at my work the code was P0171 and said the system to lean in bank 1... any certain vacuum lines i should look for that are loose or lines i should look for.. i cleaned my maf and it was not that dirty and everything else looks fine to me...
  2. Ronnie@RSmotors
    Get a freeze frame.
  3. JasonoJordan
    change the fuel filter maybe getting plugged
  4. aj99civic
    aj99civic Member
    ok i will.... this sounds dumb but what is that anyway.. i seen it on the obd2 scanner....
    ill be putting one in today hopefully
  5. JasonoJordan
    i had that same code when i got the car changed the fuel filter and it went away
  6. aj99civic
    aj99civic Member
    really? yeah i did checking earlier and senn alot of things it could have been. but its just strange how it happened... just my luck we have no filter in stock..
  7. Rexwagon
    Rexwagon Well-Known Member
    just get one at auto parts store. they are easey to change, its the upper driverside by the firewall.
  8. JasonoJordan
    yea any autoparts store will have them
  9. aj99civic
    aj99civic Member
    just changed the filter and i was looking and it seemed the 02 sensor was a lil loose to so i guess ill see after work if anything has improved....
