check engine light, P0244
Discussion in 'Modifications And Maintenance' started by heavy hauler, Feb 4, 2010.
  1. heavy hauler
    heavy hauler New Member
    ok, today driving home, 5th gear, 60-65 mph. the car stuttered. blew cel,
    car 2006 wrx, 60,000 miles, mods, perrin drop in filter, cat back with silencer removed, cobb stage 1.
    checked code then cleared.
    any idea why i would blow a wastegate code?
  2. turbo_turtle
    Your wastegate needs to be tightened. IIRC, this was a common problem with stage 2 WRX, MY2006 with aftermarket exhaust. I have not heard of it happening with stage 1 though. It's no big deal, the wastegate pressure was set too low from the factory. The solution is to tighten the wastegate arm until you get to the correct boost pressure for your setup, then reflash and drive happy. I can show you on Sunday.
    ~Dan
  3. Nuke
    were you stepping on your gas in 5th gear trying to speed up/pass somebody?
  4. heavy hauler
    ok, dan, thanks..
    i was not passing, or excellerating hard.
  5. zisson33
    zisson33 Well-Known Member
    What if he was? What were you thinking?
  6. Tim the Plumber
    5th gear is a pretty heavy load gear and can cause "over boost" i believe. I did it in my buddys 05 sti once. someone can correct me if im wrong
