check engine light
Discussion in 'Modifications And Maintenance' started by Scott, Oct 8, 2011.
  1. Scott
    Scott Well-Known Member
    I just had c.e.l come on.took it to Autozone.they said it was a cylinder 4 misfire. Asia to run some injector cleaner. And the light may go off soon. Any advice? Its an 02 wrx no mods with 93the thousand on the clock.
  2. driftin240
    driftin240 Well-Known Member
    Time to do a valve clearance check, unless of course the plugs have never been changed. If it's in need of a vlave adjustment, do yourself the favor of doing it before you burn the valve and destroy the seat in the head.
