Cleaning MAF
Discussion in 'Modifications And Maintenance' started by HawkEYedREX, Jun 30, 2014.
  1. HawkEYedREX
    HawkEYedREX New Member
    Car has 80k all stock. Air filter is getting replaced and wondered if the MAF had ever been cleaned. I have read a thread on Nasioc but am still unsure what portion(s) of the sensor I should be cleaning. Anyone have pics or videos?
  2. idget
    spray inside the tube, invert, repeat, then let dry.
  3. HawkEYedREX
    Perfect thnx
  4. xodad2
    xodad2 Well-Known Member
    There is a thread on here. Look in the diy section.i believe it says to clean the wire on the side.
  5. joebush44
    joebush44 Well-Known Member
    There's a tiny little wire down inside the tube. That's what you want to get clean. But try not to blast MAF cleaner directly at it so that you damage the wire...
    xodad2 likes this.
