Clutch install Q
Discussion in 'Modifications And Maintenance' started by silver03, Dec 10, 2012.
  1. silver03
    94 legacy L awd. Drop tranny or slide motor forward? Thanks
  2. Terry Ammerman
    Pull the engine. Pretty easy.
  3. mke723
    mke723 Well-Known Member
    dropping the tranny is easy, remove exhaust, drop propshaft (drive shaft), undo shift linkage, then trans to motor bolts, then trans support... only takes 90 or so mins. (with air tools)
  4. SeanKelly
    SeanKelly Member
    Any way you go about it, its a pain in the butt.
  5. silver03
    Re: dropping tranny. Front cv axles need to be pulled...correct?
  6. kvang
    kvang Well-Known Member
    ^NO^
    Tash likes this.
  7. xluben
    I agree with the above. For a clutch change just pull the tranny back and leave the front axles connected. You should have just enough room to get a clutch in/out.
  8. GiMp
    GiMp Well-Known Member
    Kvang does tranny swaps at BIR he would know :)
  9. silver03
    How can this be?
  10. idget
    there's enough slack in the axles that you can move the trans about a foot rearward
  11. xluben
    Axles still installed:
    silver03 likes this.
  12. silver03
    I was committed to this^^ for an hour...and than pulling the engine seemed much easier (no hoist). So, I ended up pulling the motor.
  13. xluben
    I've had my tranny separated from the block at least half a dozen times in the last year and I did it all on jack stands. Probably takes an hour to get to that point.
  14. Tash
    Tash Well-Known Member
    Soon to be at least half a dozen plus one last?
  15. gran0393
    gran0393 Well-Known Member
    Yeah I can do a clutch in the garage in about 4 hrs
  16. gran0393
    sliding the tranny back is really easy
