Clutch Shudder at Start of Day
Discussion in 'Modifications And Maintenance' started by stuffelse, Sep 17, 2009.
  1. stuffelse
    stuffelse Well-Known Member
    When I first start the car in the morning, the first few times I disengage the clutch, unless I really tach it up and burn the clutch excessively the first 10-15 times, it shudders somewhat violently. The symptoms subside usually around the same time the car approaches full running temp, and don't come back unless the car sits for quite a long time, i.e. overnight.
    My clutch never slips under normal use, behaves pretty normally other than this. My first idea is leaking rear main seal, but it's not leaving puddles and doesn't appear to be losing oil. Ideas?
  2. predavore
    predavore Well-Known Member
    What year? Mods? Mileage? Type of clutch?
  3. AWDimprezaL
    Pretty common, pretty much matters on how the clutch was broken-in.
  4. JasonoJordan
    if its anything but a stock clutch or if its a new clutch they tend to do that my exedy stage1 does the same thing
  5. Shibbs
    I've noticed my stock clutch in my 07 is a bit picky in the morning, but never anywhere close to violent.
  6. 9blackmax6
    mine does the the same thing also. I'm not leaking any fluids nor is my clutch slipping. I think you'll be alright
  7. sneefy
    sneefy Well-Known Member
    Common. I know there is a TSB out for 'cold clutch judder' for 02-03 models (I think).
    You learn to shift around it.
  8. stuffelse
    Oh yeah, good point. ~142k miles, not sure if the clutch is original or not, I'm sure it's factory though. I've only had the car for a few months.
    Sounds like there's not much to worry about though
  9. AWDimprezaL
    Stuffelse ftw.
    Ride your honda, stop driving the subaru, there will be plenty of subaru time coming VERY Soon.
  10. stuffelse
    Would have rode the Honda today, except that I had no coffee cup holder on the bike. Try to not ride in when I'm not quite awake yet. I'd hate to do something stupid on the bike cuz i'm tired.
  11. mnstilynwrx
    mnstilynwrx Well-Known Member
    mine does the same thing... any ideas on what it would be? it does it a lot after a damp or rainy night. Maybe condesation in the clutch??
  12. AWDimprezaL
    The clutch isnt flat anymore, sometimes you can fix it with a nice good slip, somtimes not, I would deal with it before slipping the sht out of it.
  13. Tim the Plumber
    mine does the same thing and its pretty violent... but then again i have a 6 puck
  14. stuffelse
    Quoted for posterity. :biggrin:
