clutch will not engage works in reverse?/ Help anyone
Discussion in 'Modifications And Maintenance' started by Redbull1, Aug 20, 2010.
  1. Redbull1
    Redbull1 New Member
    So I have a 02 wrx and a couple weeks ago my clutch pedal started to feel little lighter and spungy - now clutch will not engage unless your in reverse any ideas?
  2. Shane86
    Shane86 Well-Known Member
    I had a bit of a similar problem.
    Bleed the hell out of the system. it may be an issue with old fluid or air bubbles causing the slave cylinder not to actuate fully.
    it may be worse though, check around both the master and the slave cylinders for apparent leaks.
  3. Redbull1
    Redbull1 New Member
    Think it may be the clutch? pressure plate?
  4. Redbull1
    Redbull1 New Member
    Ill check for leaks too thanks
  5. Redbull1
    Redbull1 New Member
    where exactly are these?
  6. rst
    rst New Member
    Try bleeding it see if that works.
