Cobb Stage 2 question
Discussion in 'Modifications And Maintenance' started by jdmspecWRX, Dec 15, 2008.
  1. jdmspecWRX
    jdmspecWRX Well-Known Member
    I just got an AP, but I don't have the complete turbo back exhaust....can I still run stage 2 with the following:
    -Catback exhaust (Greddy Evo2)
    -Borla Headers
    I am planning to get the downpipe and up-pipe in the Spring, but not now. Any thoughts?
  2. Paul Revere
    Run stage 1
  3. Moleness
    ^^^yes this, until you get the DP
  4. mnstilynwrx
    mnstilynwrx Well-Known Member
    dont run Stg2 without DP. get that and its good to go. if your looking for a up pip i have one for sale.
  5. wrexinator03
    wrexinator03 Banana Cream
    ^what they said....pick up an erz or srs downpipe on ebay been running mine for almost 2 years now works great and CHEAP!!
  6. jdmspecWRX
    mnstilynwrx: what brand downpipe is it, how long have you used it for, and how much for the downpipe?
    wrexinator03: I hear the erz and srs has fitment issues......is this true?
    any advice, feedback.....
  7. curly2k3
    "issues" are all relevant. they all can be a PITA at times, remember, you get what you pay for. but in reality, they are far better than stock without a doubt, and it would allow you to really access the power at hand.
  8. esperunit
    esperunit Well-Known Member
    WG duty cycles will be screwed if you run stage 2 on that.
  9. Nuke
    timing and fuel also.
  10. WRX1
    Well, really, everything will be screwed since you have a header. Best bet is to keep it stock till you can do the whole thing. The header will effect flow as much as a downpipe, then having the stock downpipe will kill flow. Run just the catback and flash stg1 and call it a day. Once you get the rest of the parts, then you can throw the header in the mix and then you will need a custom tune. Stg2 with a header is not the same as stg2 without a header.
  11. wrexinator03
    i had absolutely no issues with my srs downpipe...went in and out just like any other down pipe i have installed...just my .02
