codes and extra plug
Discussion in 'Modifications And Maintenance' started by A.K., Jun 27, 2011.
  1. A.K.
    A.K. New Member
    put a new motor in my 02 wrx, the new 2.0 came from a 2005 wrx. i used the 05 harness and found what seems to be an extra plug.
    the check engine light came on, i scanned it, the code came out to be for the MAF so a couple days later i get ready to try and fix it and thought id scan it again. this time it says its o2 sensor which is hooked up i havent checked it yet but i found an extra plug that is the same plug as like the cps and o2 sensor. so i was wondering if the 05s had an extra 02 sensor... ? and if this could fix it http://legacygt.com/forums/showthread.php/unofficial-05-06-lgt-2-2k-5w-resistor-up-pipe-131488.html
  2. JasonoJordan
    where is this extra plug u are speaking of located at? pictures of it would help alot as well.
  3. A.K.
    A.K. New Member
    near the air box and coolant fill. id have to wait untill tomorrow to snap a pic.
  4. JasonoJordan
    whats the motor swaping into.
  5. A.K.
    A.K. New Member
    i put it in my 02.
  6. JasonoJordan
    I did the same swap and I do not recall the extra plug u speak of but pic would b sweet
  7. Threshld1
    Threshld1 Well-Known Member
    Post the wire colors and I can check Alldata too.
  8. bikerboy
    bikerboy Subie GOD
    Sounds like it would before the EGT probe.
  9. A.K.
    A.K. New Member
    nuke helped us out at calhoun yesterday, thanks guys.
  10. Threshld1
  11. A.K.
    A.K. New Member
    i need a new o2, and the plug was egt.
  12. Nuke
    I don't know...that Nuke guy's pretty shady
