Comcast and Routers/Switches
Discussion in 'Off-Topic' started by EtchyLives, Jun 16, 2008.
  1. readymix
    Odd to note, my ping time is 36ms, around 70 to California.
  2. EtchyLives
    EtchyLives Well-Known Member
    Actually, my service that I'm getting is 8Mbps. The 6Mbps was $60 since I'm not a cable subscriber. The 8Mbps is only $2/mo more AND comes with a 6-month discount rate of $35/mo.
    I hope this works out well. I'll be pissed if I go through the trouble of swapping service and things still suck.
  3. EtchyLives
    MY ping rate last night went over 400. Is there anything I can do to lower my latency? I'm changing services tomorrow morning but if there is something I can do with my modem/WAP to make it faster I'd like to try. I'll be running a Motorola Surfboard.
  4. Bullwinkle
    Ping to what? If it was in TF2, I can toss you a couple ingame rate commands to try to straighten that out.
  5. retreif
    What os are you using and are you wireless?
  6. EtchyLives
    I was using Win Vista Ultimate and yes, I am wireless. I've got basic WEP encryption.
    Nate, please send me those commands.
  7. Vector
    Vector Rally Organizer
    What's the IP of the server?
  8. EtchyLives
    Nate, does this sound right?
  9. retreif
    pulled the service pack yet? Wireless will add latency.
  10. nm+
    nm+ Professional Hypocrite
    Screw qwest, screw comcast
    visi FTW
    Uses qwest lines, but you never have to talk to them
    7M line
    Actively encourages hosting, no filtering or caps (if you were using 7M 24/7, they wouldn't care as long as you weren't reselling bandwidth), all ports, no downtime (and I mean not 1 second I'm aware of) in at least a year
  11. readymix
    I'm Comcast and my game machine is wireless. You've seen my pings. I think Smiley's 2Fort I ping a consistant 10-15.
  12. stoooo
    stoooo Well-Known Member
    Comcast Business Class is the same way, except that the tech told me they don't even care if you do resell the bandwidth, since you're already paying for it.
    My boss had Comcast Residential up until they switched off port 25 a couple of months ago. He upgraded to Business Class in a hurry, and is absolutely delighted with it.
    Your choice of service really does depend on your intended use. Don't get mad at Comcast because you can't run your server farm properly off their Residential offering. Same goes for DSL. DSL's advantage is that it reaches places that cable doesn't. Consider yourself lucky if you have a choice of providers.
    Stuart.
  13. Bullwinkle
    Yeah, those look close. Those commands are the first I would play with if your ingame latency is abnormally high.
  14. nm+
    This is their residential offering
    What does comcast want for business class?
    This is ~$40/mo
  15. stoooo
    I think it's about $60 right now with a two year agreement. Costs more if you don't sign up for the long term. You can also add static IPs for a little extra per month.
    Stuart.
  16. nm+
    That's not that bad, but a bit more $$$
    This is month to month though (no contract). Comes with static IP.
  17. EtchyLives
    Nope. No SP1, yet. I should do that but I'm about *this* close to going back to XP on the big compy (only for SLI. Otherwise I really like Vista).
    When the cable gets installed the big computer will be hardwired into the modem and everyone else will have to suck at the wireless teat. The Qwest modem is too far from ANY computer to get a hardline.
  18. fondune
    I got a sweet deal on a 50 foot cat6 cable...but wireless can be nice too. mmmm...teats.
  19. EtchyLives
    I have about 300 feet of CAT5 cable, a cable crimper and connections but I don't want to drill holes in the wall or trip over cable. Plus, every computer (all 4 of them) has a wireless card or built-in adapter.
  20. EtchyLives
    New stats. Me likey.
  21. Vector
    Keep in mind that Comcast has a "burst" speed which make things like speed tests look a lot faster than sustained bandwidth will really be.
