compression Checker
Discussion in 'Modifications And Maintenance' started by Taras, Jul 2, 2008.
  1. Taras
    Taras BANNED
    Looking for a compression checker tool. never used it so i am not even sure how it looks. If anyone has one, it would be nice if i could barrow it for a day or so.
    Thanks, Taras
  2. predavore
    predavore Well-Known Member
    They are cheap. Go to NAPA and get one. They are around $30. Very useful tool to have around if you are buying (or selling) used cars.
    The way they work is that you disable the injectors and spark plugs. This is done differently on various cars. On my Evo, all I had to do was unplug the crank sensor. Boom, disabled everything necessary for me to run the compression test.
  3. Taras
    Taras BANNED
    cool, thanks.
  4. Chux
    agreed. just buy one. they screw in in place of the spark plug.
  5. DGRx
    DGRx Member
    I have one you can borrow. Located in BP. MN.
  6. Taras
    Taras BANNED
    Cool, i will see if i can get one at NAPA if its cheap i will buy it if not i will PM you.
    Thanks.
  7. DGRx
    DGRx Member
    Okay.
  8. sjwelna
    sjwelna Well-Known Member
    Don't forget to make sure you hold the throttle at WOT while cranking the car to check the compression too.
    -Steve
  9. Shibbs
    Not necessarily true on Drive By Wire vehicles. ;)
    But I'm assuming this is for the Miata, so yes, WOT while cranking.
