Contrast adjust on my Alpine deck
Discussion in 'Modifications And Maintenance' started by Paul Revere, May 21, 2008.
  1. Paul Revere
    Can I adjust the contrast of my deck if I hook up the yellow wire with the dimmer control? I know you can with gauges, I guess sometimes I don't want all the bright lights on the dash. Or can I go to Radio Scrap and get some kind of adjuster?
  2. readymix
    If they are LEDs then probably not.
  3. Paul Revere
    Damn I bet they are, why is that Jason?
  4. readymix
    Also, RTFM. I'm sure it tells you in the wiring diagram if it connects to the interior dimmer wire, and if it can dim with the cabin lights.
  5. driftin240
    driftin240 Well-Known Member
    I doubt that you'll get full control over it, but it may dim down a step or two. Most Alpine decks have a contrast setting in them. Go read the manual.
  6. readymix
    Because typically, LEDs require a certain bias voltage to illuminate, and have a max voltage range before they are cooked. But usually intensity doesn't change much on an LED unless it specifically allows for it. For long life, electronics manufacturers will probably bias an LED at or near its lowest required voltage and current. You'd likely only be able to increase intensity, not decrease it.
  7. Paul Revere
    Oh you two are so smart, I would read the manual if I wouldn't have puked all over it on my 21st last year :(
  8. driftin240
    Go online and look up a fresh copy. n00b...
  9. readymix
    That's your own idiot-ass fault. Alpine has the manuals on their website in the support section.
  10. Paul Revere
    So it says "orange illumination" to the instrument cluster illumination lead, whats the worst that could happen?
  11. curly2k3
    fry the circuit
  12. Paul Revere
    Well I definitely wouldn't let you do it mister no brake lights!
  13. curly2k3
    i have brake lights numb nuts.
  14. driftin240
    If you hook it up to an illumination switch (ie. your dash clock) I bet it dims the deck by about half. It's not going to be adjusted like you think via the dimmer switch.
  15. Paul Revere
    There was a point in time that you didn't fag breath.
  16. curly2k3
    there have been points in time where you had no oil in your car, gas spewing everywhere, barbi wheels...need i go on there skipper?
  17. Paul Revere
    Those were low points I will give you that (except the Barbi wheels I like those) but I am now past those times ... I hope
  18. readymix
    So, is the orange wire connected to the illumination lead on the car harness? Or is it not connected? Or did you connect it to something else?
    If it is connected and the dimmer switch doesn't dim your stereo, then your question is answered
  19. Paul Revere
    No it was never connected, it is taped off wrapped in the harness.
