converting side feed to top feed in LGT
Discussion in 'Modifications And Maintenance' started by 05MNLGT, Mar 10, 2016.
  1. 05MNLGT
    05MNLGT New Member
    Maple Grove
    i have a 2005 LGT 2.5 limited wagon (pd: 8/04). i'm wondering if my stock side feed manifold intakes (14011AB431/14011AB441) can run top feed injectors or do i need 07 manifold intakes? i'm wanting to try to keep it oem vs doing the injector convert kits.
    i have a 07+ LGT/STI fuel rail. the question is can stock intakes work? the engine is broke down and being rebuilt this month. body is being prepped for painting.
    thanks,
    Michael
  2. derp
    here and now
    good thing you posted the same thread twice, you'll probably get an answer that way good thing you posted the same thread twice, you'll probably get an answer that way
    Ntxhuav_Khang likes this.
  3. derp
    here and now
    k but for real though, have you looked around on legacygt.com? otherwise @Aluminati might be able to get you a part you need?
    Ntxhuav_Khang and Deathly like this.
  4. iand464
    iand464 Well-Known Member
    Hudson, Wisconsin
    I think the intake manifolds are the same but the tgv housings are not. You would need top feed tgv housings and then top feed injectors. the injectors go into the tgv housings not the intake manifold.
  5. 05MNLGT
    05MNLGT New Member
    Maple Grove
    yes i meant tgv. subaru lists them as part of intake manifold. crap they both look so simliar visually. thanks.
  6. 05MNLGT
    05MNLGT New Member
    Maple Grove
    thanks for the outstanding advice.
    derp likes this.
  7. 05MNLGT
    05MNLGT New Member
    Maple Grove
    yep. tried them all. this was my last effort. i have all the parts lined up. thanks
  8. 05MNLGT
    05MNLGT New Member
    Maple Grove
    phi11 and tangledupinblu like this.
  9. derp
    here and now
    You weren't kidding. Basket case? Or just refresh?
