Coolant lines locations
Discussion in 'Modifications And Maintenance' started by Shibbs, Mar 28, 2009.
  1. Shibbs
    Looking for a diagram for the coolant lines under the hood. Basically I'm wondering if coolant runs thru the throttle body.
    2007 WRX
  2. Jackstand
    Jackstand Well-Known Member
    I know it did on my wrx but yours is controlled by the ECU so IDK
  3. Shibbs
    ;) Hence my question.
  4. Snowbum
    Snowbum Well-Known Member
    Go feel around the TB for rubber hoses. Are you wondering so you can bypass them?
  5. FuJi K
    Look at the black hardpipe that runs along the edge of the head and block on TOP of the motor. There you'll see a small hardpipe from out from it, then a rubber hose connected to it via clamp. It'll run and turn a few turns and come to the throttle body. The exit will come out and into the crossover pipe.
    I just by pass it by connecting those hoses from the little black hardpipe to the crossover.
  6. Shibbs
    I was digging around on alldata, no decent picture. Fuji, you know what size they are by chance? haha
    Yes, I want to bypass it.
  7. piddster
    Why do you need to bypass it?
  8. Shibbs
    H-PEEZ gain, y0. :biggrin:
    Or wouldn't it be worth it?
  9. Snowbum
    I dunno if anyone has dont a comparsion for the bypass. I would like to see how effective the bypass is at lowering the air temp.
  10. piddster
    That little bit of heat you actually get from the small amount of coolant circulating through the TB is a drop in one very large bucket. Clean the dirt and bugs out of your intercooler if you are that worries about it.
  11. Shibbs
    lol yeah, that's what I was thinking. :laugh:
  12. wall of tvs
    Not worth it.
    Turn your boost up more. :biggrin:
  13. driftin240
    driftin240 Well-Known Member
    Shibbs, I'm not so sure they even run coolant through the DBW throttle bodies. I haven't taken a look at one on a WRX in a while, so I could be wrong. Even if they did, like everyone else has said...it's a tiny bit of coolant, which can't superheat your throttle body.
  14. FuJi K
    The STi's and '06 WRX I've taken apart still runs it through.
  15. WRX1
    ZOMG, don't do it. Your throttle body will freeze shut.:laugh::biggrin::laugh:
    Man, if I had a dollar every time I heard that, I could buy everyone a new car.
  16. Shibbs
    Truth. I did it in my Fiero (rear-engine, intake on the rear quarter panel, true cold-air from the factory) and it made a decent difference in throttle response. And it didn't freeze shut like everyone said it would. :laugh:
