cv joint noise... i think
Discussion in 'Modifications And Maintenance' started by subaruski, Jun 24, 2008.
  1. subaruski
    subaruski Well-Known Member
    Hey guys. The outer driver side cvj boot is torn on my 98 outback. When I turn, that wheel makes a grinding noise, not a clicking noise. I'm assuming my cv joint is going out because the boot is ripped and I drove through some pretty deep water, but I thought bad cv joints click, not grind. Is this a bad cv joint? Also, how bad of an idea is it to drive from say, Madison to Menomonie (~206mi) so I can fix it at a home with a garage?
  2. readymix
    Eloh, El
    You would probably be ok driving to the garage. Hard to say, depends on how long it has been bad.
  3. AWDimprezaL
    Monticello.
    the CV is probably not making noise yet, however i bet your wheel bearing is toast
  4. subaruski
    so its probably the bearing thats grinding and not the cv? should i replace the bearing and the cv? would it be better to just do the whole axle?
  5. AWDimprezaL
    Monticello.
    That would be your best bet, i know it took almost 2 years for my CV to start clicking
  6. subaruski
    so you think the cv might actually be ok?
  7. AWDimprezaL
    Monticello.
    well its never OK for it to be open, but its just probably not the problem
  8. angusracer
    angusracer Well-Known Member
    i actually have the same problem in my 02. it's quiet in a straight line but if turn at all it starts squealin. my boot is torn aswell. no clicking though.
  9. Hallywood
    Hallywood Well-Known Member
    Bloomington MN
    I had to replace my entire hub assembly cause I drove on a bad wheel bearing for so long. Get it fixed, whatever it is, or pay the price.
