DEI exhaust wrap
Discussion in 'Modifications And Maintenance' started by Scuba Steve, Mar 12, 2008.
  1. Scuba Steve
    I know this was posted before, but i couldn't find it so here's my question.
    DEI exhaust wrap. 2"x50'. 54.99 plus spray and clips
    Good deal?
    I need to wrap some pipes soon.:cool:
  2. AspitFire
    i would so
  3. idget
  4. readymix
    I got ebay wrap, it's held up fine thus far. Paid 40 bucks shipped for 100' of black.
  5. Scuba Steve
    thanks...I'll search ebay and check out summit
  6. Dynapar
    That seems decent. I got the DEI wrap for I think $29 and another $10 or so for the fancy high temp spray. I used hose clamps instead of metal ties though. The stuff seems to hold up alright. It was fine on my uppipe, but it needs to be re-coated fairly often on the DP. also if your exhuast (dp most likely) rubs on the ground at all this stuff will not last. Mine DP was super frayed.
    heres a pic of my down pipe. I have <10,000 miles on it. the wrap was just trashed in the last 3k.
  7. idget
    another place to check for rubbing is on the subframe pinch weld closer to the passenger side if yr planning on wrapping aftermarket headers. A lot of them scrape there.
    Some strategically placed clamps and sound deadening did the trick for me (rather than cutting the pinch weld).
  8. Nuke
    Mine is starting to look like that, not that bad, but it's been about 15k on it. I bought it used with wrap on it too, and it had some miles on it before.
  9. matt_wong
    matt_wong Well-Known Member
    My downpipe is only wraped on the shorty part. Is it a necessary to do the rest before I put it on my car or is it ok.
  10. idget
    ^its fine, the shorty section extends outside the engine bay. Probably better that way so far as wear and tear goes but it's hard to wrap half of a 1-piece downpipe.
  11. Nuke
    Yes, just wrap the shorty dp and that should be fine. Any more, and it'll just get ripped up by stuff off the ground.
    As for wrapping, if you can get a second person to help, please do, lol.
  12. Dynapar
    Wrapping takes some practice. I took me 2 or 3 times to get really good at it. It is tricky going from the odd shaped bellmouth and right onto a bend. Make sure to get it good and tight though. Mine was holding it self in place w/o clamps.
  13. Scuba Steve
    thx for the input guys. It's appreciated!
    No, mine doesn't rub on the tranny crossmember and never touches the ground...thank goodness
  14. Nuke
    Never seen any DP touching the ground...
  15. Dynapar
    ^ mostly it is when you are going over bumps and the exhaust is the lowest part of the car.
  16. curly2k3
    my exhaust has hit the ground a few times, the DEI i have seemed to have been holding up last time i checked, but i think its all but gone by now
  17. Scuba Steve
  18. WRX1
    I have a 50' roll of the copper wrap I will sell ya for $50, and I have some ties and clips also.
  19. piddster
    The wrap on my exhaust manifold has lasted for over a year of daily driving. Paid $22.
  20. AspitFire
    thats a good deal, the copper stuff is usually more $$$
  21. hella_sti
    hella_sti Well-Known Member
    dip the stuff in water before you wrap it, thats what I did with my thermo-tech black wrap and its holding up great!
  22. Scuba Steve
    pm sent to ya russ
  23. DISCOPOPE
    DISCOPOPE Well-Known Member
    water is the key, if you do the black though, make sure you do it outside, the pigment gets all over everything.
