Diagnosed as bad Catalytic Converter
Discussion in 'Modifications And Maintenance' started by MBOUTBACK, Dec 21, 2009.
  1. MBOUTBACK
    MBOUTBACK Active Member
    So my 2000 OB recently started doing something disturbing. When accelerating you get occasional "pops" that feel like all the power isn't transferring to the road. Our mechanic said it was the catalytic converter, but I'm skeptical. I'm curious if anyone has seen this before.
    Thanks for the info,
    Markus
  2. errorcode3
    errorcode3 Member
    they can cause a loss of power, does the car smell like rotten eggs? that can be a give away too.
  3. MBOUTBACK
    No rotten egg smell...
  4. AWDimprezaL
    Pull a plug wire out of the head, I bet its soaked in oil, time for plugs/wires/valve cover gaskets.
  5. MBOUTBACK
    I'll check that when I get home. Am I doing any damage if my wife drives it for a little while?
    As I recall, valve gaskets on the OB are pretty easy...Few bolts. Anything I should be carefull of?
    Thanks again,
    Markus
  6. pksublime
    pksublime Well-Known Member
    suck man, want any help once you figure it out?
  7. AWDimprezaL
    5 bolts per side, super easy job.
  8. pksublime
    okay it's easy markus, but it's still an excuse to hang out
  9. MBOUTBACK
    C'mon over!
  10. MBOUTBACK
    Thanks for the help yesterday. I bought the parts on the way home from work, and everything works perfectly now!
  11. pksublime
    good to hear
  12. ofspunk7
    Was it the plugs?
  13. AWDimprezaL
    Good to hear! So I was right?
  14. pksublime
    i didn't make it over, and you'll probably not see him for a while
    i'll try to remember to find out
  15. MBOUTBACK
    Thank you! You were correct sir! I award you one point* for properly diagnosing a car via the interwebs.
    *points are non-refundable, non-redeemable and have no value, let alone cash value. But that point made you feel good about yourself...didn't it.
  16. AWDimprezaL
    LOL, glad I could help.
  17. pksublime
    i stand corrected and without any points
  18. MBOUTBACK
    Oh, and I took all the credit...my wife thinks I'm a genious...
    Thank you!
