Downpipe Options for Wideband?
Discussion in 'Modifications And Maintenance' started by tux121, May 14, 2008.
  1. tux121
    tux121 Well-Known Member
    I wasn't sure so I wanted to ask if there are any aftermarket downpipes that already have a o2 bung for the wideband sensor? Maybe if anyone has one sitting around I could buy:) I know Cobb has one but is that my only option? I don't want a custom one welding on.
  2. Nuke
    just get it install
    want me to bring up taras' thread?
  3. tbone
    tbone Well-Known Member
    you could take the rear 02 sensor out and replace the wideband......but you want it close to the turbo, maybe about 6-12 inches away from it, that way you get the acurate (don't know how to spell it) readings.
  4. tux121
    get what installed?
    bring it
  5. TSTRBOY2004
    an 02 bung....
  6. tux121
    On to my current downpipe? You have an ideal cost, time, place? :biggrin:
  7. Nuke
    Go get a quote from a shop
  8. TSTRBOY2004
    is it stock or aftermarket??
    aftermarket I would say $20 if you supplied the bung.. maybe $30 if the shop supplies it...
    I did a few of them when I had my shop...
  9. tux121
    Darn then I have to take out my downpipe. For now I can't afford to do that since I am stuck driving my car for awhile.
  10. curly2k3
    you bought the wide band stuff buy you cant afford to have a bung welded in?
  11. sjwelna
    sjwelna Well-Known Member
    Helix...Cobb....a lot of aftermarket DP's have an extra o2 bung right near the turbo for a wideband. What one did you get? I have a helix and when I get the money I'm going to install an LC-1 wideband in it permanently.
    -Steve
  12. tux121
    When I said afford I meant afford to not have my car running anymore.
  13. TSTRBOY2004
    and it CAN be welded while on the car.. just a lot harder
  14. Justin
    Justin Well-Known Member
    ours will. our bellmouth will be a mold and the 02 bung will be molded into it.
  15. esperunit
    esperunit Well-Known Member
    I have always heard the cobb bung was too close to the turbo to be useful for a wideband but honestly I have never seen any written up evidence that actually says so.
  16. Bullwinkle
    Actually, the close position is likely the most useful for pure tuning. The problem is that the sensor is more likely to burn out quickly being so close to the turbo.
  17. carl
    i have a invidia dp that has a bung at the top near the bellmouth - I put my LC-1 there. I added a large copper heatsink (as per the directions that came with the LC-1 if the sensor is mounted within a certain distance from the turbo)
  18. WRXEcho
    WRXEcho Well-Known Member
    ^^^How long have you had it in there? I have the Cobb DP and the WB bung is in the bellmouth close to the turbo as well. I was gonna' put my WB in there, but as has been said, I heard it was too close. The heat sink should help with longevity, but who wants to be spending $80 on sensors all the time :-/ But, do I want to weld into my DP when it already has a bung? I'll probably just use the installed bung.
  19. gc8
    gc8 Well-Known Member
    when is that gonna make its debut?
  20. Justin
    soon. prototype is on the impreza right now.
