DP wrap
Discussion in 'Modifications And Maintenance' started by issues, Oct 7, 2010.
  1. issues
    issues Well-Known Member
    I just got an invida dp and was wondering how much heat wrap it takes to do it correctly as I dont want to buy the 50ft roll if I dont have too.
  2. 03subyR
    03subyR Well-Known Member
    1" wide 25ft should be ok.
  3. issues
    so 2" 15 foot should be ok?? btw I only plan on going down to the hanger about mid way
  4. scotty
    scotty Well-Known Member
    That should be fine, don't waste money on the stainless ties they try to sell you either, just go to napa or menards and get stainless hose clamps (the worm gear kind).
  5. goodhart
    goodhart Well-Known Member
    ^^ What he said. Those steel zip tie things are highway robbery and all they do is come loose and cut the crap out of your hands. Some worm drive hose clamps will work just as good.
    Also, Get the wrap wet before you apply it. A friend showed this to me before I wrapped the DP on my WRX last year, made it about 107% easier. It is much more flexible and easier to get around the bends, then when it dries it gets nice and tight.
  6. 03subyR
    That's a good tip. Learn something new everyday.
  7. strangefamous
    Also dont wrap the whole pipe. Stop where is bends underneath the car. Otherwise it will get shredded quickly and you will just have to end up redoing it. Also another good tip is to leave about a quarter inch or more unwrapped at the belmouth. If you dont it can be hard to get the bolts in at the turbo.
  8. goodhart
    Here's a pic, just so you have an idea of what it should look like. I didn't leave the 1" gap and did not have any issues with this ERZ catless.
  9. strangefamous
    How did it go?
  10. issues
    It went well no leaks it just stinks and under hood temps went way down holy crap! thanks for the info guys
  11. strangefamous
    Did you put it on before it was dry?
  12. goodhart
    Yea, it is normal for the wrap to stink for a while. Probably about 50-100 miles depending on the weather, your driving style, etc
  13. issues
    It sat for 18 hrs before I put it on and I couldnt feel any moisture on the wrap. Ill have put 120 miles since I installed once I get home from work tuesday.
