Dripping oil
Discussion in 'Modifications And Maintenance' started by 03subyR, Jan 11, 2009.
  1. 03subyR
    03subyR Well-Known Member
    Dripping oil from turbo banjo bolt location. It does not leak bad, just a little quater size wet spot in my garage. Check oil daily and it does not change much. I just replaced my turbo oil line with P&L oil line kit. I did reuse my copper washer for the banjo bolt to turbo connection. Just wondering if there is something better to seal those banjo bolts?
    I am using 10mm stock banjo with DB 18G turbo, not sure if it matters.
    Will take any advice.
    Thanks,
    Max
  2. Nuke
    just retighten it, you should be fine.
  3. RichWRX
    RichWRX Well-Known Member
    I would just replace the copper washers, be careful not to overtighten them. I crushed a few washers before I figured that out :)
  4. 03subyR
    I think that is my problem. I overtighten them :(
  5. RichWRX
    you should be able to get new washers at any auto parts store.
