E-Brake Not holding
Discussion in 'DIY Instructables' started by Herb Miller, May 8, 2017.
  1. Herb Miller
    Herb Miller Active Member
    The e-brake on my 2008 STI is no longer holding. I have adjusted it as far as I can at the handle, so it looks like it needs to be adjusted at the wheels as well. However, I have aftermarket rotors that do not have the access hole. Does anyone know how I adjust the brake at the wheels without pulling the rotor. I prefer not to remove the caliber if I can help it, given the risk of stripping the caliper threads.
    Any help would be appreciated. Thanks.
  2. JasonoJordan
    Online
    Before you go adjusting anything its always best to check to make sure your pads are not just worn out for the parking brake. That said I understand why you want to avoid removing the calipers but that is the best route to go.
  3. Herb Miller
    Thanks. I will check. Wish me luck with the caliper bolts.
  4. JasonoJordan
    Online
  5. Krazylegz1485
    The Subaru community as a whole has their fingers crossed for you.
    my97gt likes this.
  6. predavore
    predavore Well-Known Member
    For one... I learned long ago, keep OEM rotors on the car. Buy a second set and turn/swap until they don't turn them anymore. Second, the shoes shouldn't hinder you from removing the rear rotor. So if you turned them, clean up the rust edge and adjust them until they (ever so slightly) rub when putting them back on.. I had to adjust mine several times (i have the adjustment hole) until they were right and it would hold within 3-4 clicks. It will loosen and wear in to 4-5 clicks after a bit. But it's flawless.
    Good luck with the bolts. Replace them if you can, or anti-seize them a bit. If you break the bolt, just remember it can be fixed. Do it when a machine shop is open.
    I did the ebrake on my WRX and learnes this lesson. I also had the rear drums done on my Forester and had to adjust them a bit afterwards. Same process.
    Aegis and tangledupinblu like this.
  7. xsmooth69x
    xsmooth69x Member
    Just make sure you E brake isnt on when you try and take off the rear rotors
    When you put the brake calipers back on just coat them with nickle/copper anti seize and the next time will be 100% easier
