Ebay exhaust? FMIC? Gauge Pod? BOV? Alum Radiator?
Discussion in 'Modifications And Maintenance' started by Taras, May 6, 2007.
  1. Scuba Steve
    something like this....(roughly)
    take off splash guard on passenger side fender well (in front of wheel well). Remove two 10mm (maybe) nuts holding the huge elbow in place. (silencer elbow is about 1 ft. wide by maybe 2 feet tall) they are located 1/2 way up in the fender well. inside the engine bay you will then remove the one 10mm nut located in front of the air box. Once those are out you will wiggle the elbow off the air box and then drop it out the fender well.
    Put the fender well/splash guard back together and drive away listening to the turbo sound between shifts.
  2. Taras
    Taras BANNED
    Awesome, will do.
  3. Taras
    Taras BANNED
    Will this pod fit my car?
    Hey, i was wondering if this pod with gauges will fit an 06 wrx.
    Thanks, Taras
  4. asiandude
    asiandude Well-Known Member
    what pod?
  5. Taras
    Taras BANNED
  6. TSTRBOY2004
    SURE!!!! just get a tube of silicone to fill any gaps around the edges....
  7. tangledupinblu
    You don't want that gauge cluster...It is a pain to find any parts that you'll need and the gauges are a smaller size, (45mm) I think, standard size is like 52mm. There are a few vendors that sell aftermarket gauges in the 45mm size, but they are not as easy to obtain as the 52. Just an fyi! I would go straight to the Defi 52mm or another brand in the same size! There are many tasteful ways to do the larger gauges. You don't have to do the clock replacement one. Also, I don't know if they will fit the 06 dash...? Just my .02!;)
  8. Taras
    Taras BANNED
    I really like the defi gauges. But they are too expensive and have features that i dont even need. I think the clock replacement pods look the best. So this one is not the way to go?
  9. readymix
    What car?
  10. Sogonerg
    Sogonerg Anteater
    i don't see why not...
  11. Zombie
    Zombie Well-Known Member
    lol...I was thinking the same thing. It fits straight cars..
  12. gran0393
    gran0393 Well-Known Member
    yeah but the boost gauge isn't in psi and i'm guessing that silicone is def needed i wouldn't buy it...but whatever floats your boat, i'd worry about this after the car gets running though
  13. WRX1
    Sure, if you want 3 worthless gauges. If you are worried about price, just go with some autometers. The only one that is any good out of the 3 of them is the boost, and since it doesn't read in psi you next question will be how to convert it to psi.
  14. Taras
    Taras BANNED
  15. Taras
    Taras BANNED
    Aluminum radiator for 06 wrx
    Hey i was thinking what is a good radiator for an 06 wrx? Something not very expencive?
  16. Justin
    Justin Well-Known Member
    the stock one if you arent going crazy.
  17. readymix
    Yep, no reason to get an aluminum radiator, just use the stocker. It works fine. What, can't David from WMC find you a radiator for your car? They have them at the dealership.
  18. ShortytheFirefighter
    I'm curious about this as well...I thought you said he was going to put in an aluminum radiator? Or is this along the same lines as the wheels, where you have to supply your own?
  19. Taras
    Taras BANNED
    No, he asked me that he can give me credit to by my own if i want to. Or he will just put Koyo that he ususaly puts on his cars. So i guess i will just go with that one.
  20. Bullwinkle
    Can't this guy find his own parts?
    BTW, I have a stock 06 front sway, if you can get credit for getting one of those as well.
  21. Nuke
    give me the koyo and i'll give you my stock
  22. rabbit
    rabbit Well-Known Member
    lol nuke
  23. silver03
    I have some stock brake pads, stock downpipe, stock up pipe, stock springs, stock scoop etc if you need to supply more optional equipment on this car. Sorry, couldnt resist. Just teasin.
  24. Deride
    The stock radiator is aluminum.... lol
  25. RichWRX
    RichWRX Well-Known Member
    I have a front bumper beam if you ned it
  26. Taras
    Taras BANNED
    Thanks for the offers.
  27. Nuke
    quiet down dude, I'm tryna get a Koyo radiator, quit playa hatin' y0
