engine won't sit center, help
Discussion in 'Modifications And Maintenance' started by Freddy, Mar 30, 2015.
  1. Freddy
    Freddy Member
    grand forks nd
    Ok so I have spent 2 days trying to get this engine to sit centered and still cant. Over loosened everything mount, used jacks, ratchet straps, pry bars to get it to be better and still getting no where.
    Everything is poly mounts. When the engine and trans came out it all sat in the bay fine. I'm out of idea. Can't get it to sit right or the downpipe to fit.
    Anyone has this problem before?
  2. Nhibbs
    Nhibbs Well-Known Member
    Atlanta
    Was the car ever in a wreck?
  3. Freddy
    Freddy Member
    grand forks nd
    It was in a accident at 21k, has 100k on it now and everything is perfectly straight. Like said everything was normal when I pulled the engine out.
    I just said screw it and put shims under the one mount and it ok now. Not what I wanted to do though but there is nothing else I think I could have done
  4. Freddy
    Freddy Member
    grand forks nd
    ya now I have another problem. got the motor on the top centered and now the trans is hitting the tunnel. idk wtf the problem is anymore. idk if the cusco mount was not made right on the trans and it to offset. im just angry now. problem 1.jpg problem 2.jpg problem 3.jpg problem 4.jpg problem 2.jpg problem 3.jpg problem 4.jpg
