excessive oil burn off
Discussion in 'Modifications And Maintenance' started by ekrizek, Mar 2, 2009.
  1. ekrizek
    ekrizek Member
    I've got a 05 impreza WRX - my first oil changed I went to Mobile1 fully synthetic. I put in the factory suggested 4Q- after a couple weeks, it needed to added about 1Q and just checked it againa few weeks later and I need to added about another quart. I've been looking around to see what could be causing this, but I'm not really finding answers. The only thing I could think it could be is the rings wearing out, am I missing something? Anyone else have anythoughts?
  2. Shibbs
    Oil capacity with a filter change is 4.6 or 4.7 qts. That's the first problem.
    Also, M1 tends to burn faster than other oils.
  3. AWDimprezaL
    Yup, you didnt add enough oil, its 4.5 4.7. And there are far better oils out there then mobile1. Also, turbocharged cars in general use a little oil, its just how it is.
  4. ekrizek
    ekrizek Member
    well son of a bee sting, thanks for the tips guys - I must have looked at the factory book wrong, what oil do you guys use. I've been a M1 since I could drive, maybe it's time to broaden my horizons.
  5. readymix
    I use Shell Rotella-T 5w40. It's actually a FULL synthetic and has much better wear properties and longevity than M1.
  6. spoolem
    spoolem Well-Known Member
    ^^Im going to start using that oil also! Thanks
  7. webcrawlr
    webcrawlr Well-Known Member
  8. driftin240
    driftin240 Well-Known Member
    I have been using Castol Syntec after running both Mobil1 and Amsoil. Castrol has near zero burn-off, and is quite a bit cheaper than Amsoil is.
  9. wall of tvs
    Yup, same here. :biggrin:
  10. driftin240
    I got that idea from you. Very good idea too! I'm very happy that I made the switch. Still going to run Amsoil in the bike, but not in the car.
  11. webcrawlr
    GC or another flavor? I had good results (and UOAs) with that.
  12. wall of tvs
    GC is nearly impossible to find now. I've just always used the "regular" 5w-30.
  13. shineynitelite
    if you're running 5w30 that would be a good place to make changes.
  14. AWDimprezaL
    Its what subaru calls for. You may be leaking it too.
  15. WRX1
    I have been running amsoil since my days of dirtbikes/wheelers. After seeing a 40 degree oil temp drop in the wheeler just be changing from honda gold to amsoil, I was hooked.
    Also, for those looking for amsoil, I can get it to ya for cost plus sales tax.
  16. shineynitelite
    odd, when i looked it up for my 2.0 wrx it said 10w40.
  17. AWDimprezaL
    No incorrect.
  18. Paul Revere
    Every stock oil cap I have seen says 5W30
  19. Shibbs
    That's for hi-temp summer oil, yes. 10w oil is for 40 degrees F and above.
    That being said, I'm running Castrol full syn 5w40 now, will be switching either to rotella or amsoil 10w40 in the summer.
    Never had a problem with oil burnoff with any Xw40 oil in my subaru.
  20. shineynitelite
    mine said 710 :hsugh: actually now that i think of that, i'm pretty sure it said that on all data. i will have to check it out when i go back tomorrow.
  21. webcrawlr
    When's the last time you checked Pep Boys/Autozone? I scored a case a few months back but I'm seeing people post up on BITOG that they're still seeing it out there. I need to find 3 more quarts to have enough for another 4 changes. Then it may be time to move on. :)
  22. ekrizek
    ekrizek Member
    wow guys, thanks for the help!
  23. wall of tvs
    There really aren't any Autozones on the west side of town that are close enough to me to make it worth my trip.
    IMHO, the quality difference between "regular" and GC Syntec isn't worth my time, especially since I probably won't ever own a car long enough where there would actually be enough wear and tear to warrant a re-build on the motor.
  24. webcrawlr
    Just popped in a couple autozones in the past two days and each had a full slot of GC (20+ 1qt bottles). It also appears they started manufacturing again as most had 2008 date stamps. The only bad news is it's full price again. When I stocked up a couple years back it was just shy of 4 bucks a qt.
  25. Rusty
    Rusty Member
    i've noticed the running mobile 1 full synthetic in my 2.5 rs. after a while (a thousand or more) im missing a quart or so of whats recommended 5-35. would the castrol full synthetic or something else be a better option for us both? btw i was able to buy mobile 1 for cheaper then a shop at Costco :) Costco FTW!!!
  26. i_subie
    i_subie Well-Known Member
    Mobil 1 FTL!1! That's how I spun a bearing T_T
  27. AWDimprezaL
    mobile one is the equivilant to water in your oil in the rate it dissapears.
  28. driftin240
    Don't think this is an actual oil weight. Most of the Subaru vehicles have 5w-30 as the recommended oil weight(direct from the service manual), but it mostly depends on your climate variation.
  29. Rusty
    Rusty Member
    sorry i was out of it last night. it says 5w-35 on my cap, though i can and will double check. i've only heard good things before about mobil1, its makes me worry now knowing that thats what i put in and its not the best in your guys better informed opinions. thanks!
  30. driftin240
    Mobil1 isn't necessarily a bad oil, it just seems to burn off faster than some other oils. If you choose to run it, just check the level often.
  31. Rusty
    Rusty Member
    yep, driftin240 was correct. its 5w-30.
