Exhaust Gaskets
Discussion in 'Modifications And Maintenance' started by Bryan621, Dec 5, 2011.
  1. Bryan621
    Bryan621 Well-Known Member
    Anyone know where to get some? Specifically for 3.5" APS...
  2. ofspunk7
    Grimmspeed? Did you hit them up?
    I am sure you could drive over and pick one up tomorrow if they have what you need in stock.
  3. Bryan621
    I think Im gonna be needing all 3.. is that a store in the cities or something?
  4. ofspunk7
    They are a local shop in MPLS .... really close to Rosedale (35W/280/HWY 36 area)
  5. jonny8852
    jonny8852 Well-Known Member
    Or you could try maperformance in plymouth
  6. phi11
    Op is in St.Cloud.
  7. idget
    Call up importimageracing. http://www.importimageracing.com/contact/
    Otherwise, rallysportdirect. They used to have the metal 3.5" gaskets but it looks like the one they have listed online might be the ****ty leaky remflex one http://www.rallysportdirect.com/Remflex-3-1-2-inch-Exhaust-Gasket-2-Bolt-Fits-APS-3-5-inch-Exhaust
    they also carry the Grimmspeed branded gasket made for APS dp fitment.
    oakos also carries lots of gaskets. Might be worth calling them up too. http://www.oakos.com/Merchant2/merc...=355&Product_Code=GS-034001&Category_Code=224
    If you're in a bind, the gasket sheets from auto parts stores have always worked really well for me. $10 a sheet and you can cut out about a dozen 3" gaskets. I've had good luck with the all metal ones as well as the paper backed ones on post turbo connections... except for the turbo to dp... that seems like way too much hassle compared to how cheap they are.
  8. Bryan621
    Thanks everyone for suggestions. But where is that store in sc? That would be closest to me.
    And has anyone used that mr.gasket stuff?
  9. Bryan621
    Hey wheres that store in sc?
    Also would a stock gasket for between the dp and turbo work or do I need a higher temp one?
  10. AWD 101
    AWD 101 Well-Known Member
    Op = "original poster" = you...
    like idget said, if you're in a bind hit up a local parts store.
    otherwise do some research, shop around the online sites already listed (phone calls!), and get something shipped you'll be happy with long term.
  11. Bryan621
    Hahaha.... my bad... I was thinkin OP was a store in saint cloud.. I'm not really in a bind I just want to start getting stuff together.. Ive been trying to research it but I'm not really getting a whole lot.. My only concern is the gasket from the turbo to the dp, the other ones I'll just make myself..
