Exhaust Help
Discussion in 'Modifications And Maintenance' started by Jackstand, Sep 19, 2007.
  1. Jackstand
    Jackstand Well-Known Member
    Well my car is driving now... I just got it back from the Exhaust shop b/c they did full 3" pipe but when i put the gasket in where the DP meets the MP it is still leaking does anyone have any ideas how to stop it? Btw its a new gasket
  2. Nuke
    try a remflex?
  3. TSTRBOY2004
    might need a cut and reweld at one of the flanges so that they are parrallel.... but if they custom built the pipe then it should have fit...
  4. AWDimprezaL
    remmmmmmmflegs
  5. Justin
    Justin Well-Known Member
    so they didnt get the flanges right? if wrxboy was still in business i would have sent you to him to fix it for you. the remflex's may or may not work. if you have an area that doesnt get totally torqued down it may blow out. 99% of people that have issues with remflex's blowing is because of either improper torque or a badly warped mating surface.
  6. TSTRBOY2004
    if you cant find a solution I may still be able to help... I still have the welder and stuff.. just would have to work it on the driveway till I build/renovate my house garage...
  7. PRA4SNO
    PRA4SNO Well-Known Member
    +1 for nate getting a home-shop going.
    Nothing like getting to working on cars:
    1. that are owned by people who take care of them.
    2. Actually pay you what you deserve
    3. Understand how much work you're doing
    4. At your own house
    5. In a shop with little or no overhead
    6. without being away from wife and kids
    7. hanging with MNsubaru members!
  8. curly2k3
    bring it back and make them fix it?
  9. Scuba Steve
    and I bet it's leaking on the top of the pipe?
    here's acouple quick tricks that sometimes helps....
    take a jack and raise the mid-pipe so it's meets flush with the dp, then bolt it down and it should seal.
    otherwise unhook the muffler hangers so the muffler section and mid pipe has an easier time coming forward and lining up.
    Or get some sealant...I personally don't like it cause it just doesn't seem to last that long.
    if ya can't get it I'll be home around 8:30 tonight and can probably fix it for ya.... just call me if needed
  10. Jackstand
    Nope the top is sealed its right on the bottom but the flanges are perfectly strait idk whats going on. I dont want to weld it because then it would be impossibl to take out.
  11. curly2k3
    talk to Justin about those gaskets he has, maybe it will help
  12. Jackstand
    BTW 3" strait exhaust FTW!!!!!!
  13. w_o_t_boy
    w_o_t_boy Well-Known Member
    I rode in it while Justin mashed the gas on I-94 right through downtown St. Paul. Pretty loud with all those big concrete walls around.
  14. chokin
    chokin Well-Known Member
    +1 for nate too, he fixed my leak by putting a frange between the DP and cat-back exhaust.
  15. gran0393
    gran0393 Well-Known Member
    so wait nate doesn't have a shop??? did i miss something?
  16. curly2k3
    so did just checking the pipe for tightness and alignment help at all Nick?
  17. TSTRBOY2004
    yeah I sold it....
    am working on getting my garage set up but may be some time
  18. sportie_boi
    sportie_boi New Member
    if it still leaking then take it back!!!
  19. ej20
    ej20 Well-Known Member
    Get ready for my Stage 3 upgrade next spring Nate (if I got all my parts ready by then...hehehe).
  20. Jackstand
    No it didnt work idk what im going to do im tired of having it at shops so i will figger something out. It is really weird when u look at it, it looks as though it would be leaking at the top but it is leakin at the bottom. weird idk
  21. Jackstand
    Reflex FTW thanks justin it worked awesome hopefully it holds up ;)
  22. Nuke
    psh, pay me and ill help you
  23. NMDAYTIME
    NMDAYTIME Well-Known Member
    i had the same problem when i did my dp. i have a friend that told me to use tin foil. kind a goofy but it works you get enough and it seals perfectly.
