Exhaust Leak: Can has?
Discussion in 'Modifications And Maintenance' started by Soupboy, Apr 22, 2008.
  1. Soupboy
    Soupboy Well-Known Member
    St. Louis Park, MN
    It may be as Lord Subaru intended but I *think/feel* I have an exhaust leak. The sound I notice is most perceptible at partial throttle from about 2k to 3k. The sound is almost diesel-esque. n00b question but is there simply something mechanical in the turbo that might be fluttering and more audible with my Maddad Stealthback to STi Axleback set-up?
    Eyeballing the DP at the flange connections it appears, to me, that there may be leak. I need some trained ears/eyes to help diagnose. I work from home in SLP and can travel - must be clean and DD free.:laugh:
  2. Aegis
    Female
    サイレントヒル
    exhaust leak = louder rubles, just let it go ..
    jk ;) good luck figuring it out
  3. Soupboy
    St. Louis Park, MN
    Hah, if it was only more rubles... It sounds like several dwarfs are under my car whispering very loudly as a group.
  4. Aegis
    Female
    サイレントヒル
    omg exhaust gnomes, oh noez!
  5. fondune
    keep an eye on yer underpants...they'll steal em.
  6. Dream
    south
    Its going to blow up.
  7. curly2k3
    Silent Hill, Jackass
    I'd blame it on todays youth...with their ruble parts and what nots
  8. Soupboy
    St. Louis Park, MN
    Promise? As long as it happens in the next 15,432 miles.
  9. EtchyLives
    EtchyLives Well-Known Member
    MNSubaru B-Series Member# 8=====D
    Hmm. It's not from the back end, is it?
    Get some liquid gasket and we'll devalue those rubles.
  10. Soupboy
    St. Louis Park, MN
    Nossir.
    Same sound as pre- axleback swappage. I forgot to axe you when I was at your casa.
  11. Bullwinkle
    Saint Paul
    Does it sound like a really quick fluttering/hissing noise, right from the turbo area?
    If so, it's most likely wastegate flutter. It's really dang loud on my car with the TXS stealthback.
    Here's a good NASIOC FAQ on WG flutter.
    http://forums.nasioc.com/forums/showthread.php?t=1081419
    EDIT: After re-reading your description, it exactly like WG flutter.
  12. FAB KING
    FAB KING New Member
    I would get some brush on copper high temp silicone and coat the whole motor.This will fix it right up.
    If you dont want to do that I'm sure someone down here at RS can look at it and find the leak.
  13. tux121
    tux121 Well-Known Member
    Champlin
    Look for water seeping out of where the gaskets are in the TBE System. It would be alot easier it the winter time. Too "Good" it's spring!
  14. Soupboy
    St. Louis Park, MN
    Yes, this. I suspected this but Sheen proved I was indeed hearing voices. Never said I was sane...or knew shyte about karz. Self-inflicted FAIL.
  15. T-REX5000
    T-REX5000 Well-Known Member
    St Louis Park, MN...uptown really
    hey I live in SLP also and I also have an exhaust leak I know what it sounds like. let me know if you want to roll over and I will check it out.
    There is also a sea foam trick that works great if you want to do that, you will find the leak right away.
    PM me if you need help
  16. Soupboy
    St. Louis Park, MN
    Heeeeeeeeeeeeee's baaaaaaaaa-ack. Ticking, clicking, etc. Used all new gaskets on my VF39 swap. Was quiet for months and is now making a racket. Only change post swap was the addition of a Whisper (vs. stock) axleback but all the noise is coming from the engine bay near turbo.
  17. piddster
    Boostonia
    Hmmmmm. I'll be in the ga-rage on friday night if you want it looked at. Its heated, of course.
  18. Soupboy
    St. Louis Park, MN
    Thanks. I've got my Office Holiday Drunk this Friday in 'Sconi.
  19. Scuba Steve
    In the Co-Driver Seat
    I'll be around Sean if you need me to take a lookie look
