fenders rolled n pulled!
Discussion in 'Modifications And Maintenance' started by 9blackmax6, Mar 12, 2009.
  1. dipp
    dipp Well-Known Member
    who cares its a car just roll them and watch the fenders. If they start to bow just back off.
  2. 9blackmax6
    bump!
    Couldn't search mnsc since I'm not a member..
    Is there Anyone out there that can find me a thread giving more details on shops or diy's??
    I really want to be able to run 225's this summer but I've gotta get
    my fender
    liner shaved first!!
  3. AspitFire
    What else would you like to know?
  4. 9blackmax6
    idealy I would like to know if there is a shop here in MN that can roll and pull fenders or a direction I should head in to find a shop.
    but I will take any information as of now
  5. 9blackmax6
    back from the dead bump to conclude this thread for members who actually search.
    i ended up buying prodrive p1 17's a couple weeks later, 225/45/17 with an et of about 52 (fairly high) they did rub, however i got an alignment from jeff the alignment guy, he put half a degree of camber in the rears and no more rubbing, i took off that inner rubber fender lip liner to gain a couple extra mm's. i believe if i had no negative camber at all, they would rub..alot. jeff (i think accidently) gave me about .07 degrees if positive toe out, on my right rear passenger side, it rubs a bit when i go over bumps and such, but its tollerable, and i think im going to ride it out and let my tire wear itself down so it will eventually quit rubbing.
  6. illegal2.2
    illegal2.2 Well-Known Member
    baseball bat=jdm style
  7. TofuShop
    TofuShop New Member
    Sorry to bump an old thread, but i couldnt view some of the other fender rolling threads for some reason. Does anyone know who I can contact that has a 4x114.3 fender roller? I live down in Rochester and I need to get this done.
    Thanks,
    Dan
