Finally got the Project car moving forward...
Discussion in 'Off-Topic' started by TSTRBOY2004, Mar 2, 2017.
  1. TSTRBOY2004
    looking more like yours in your spandex ski suit
    predavore likes this.
  2. TSTRBOY2004
    little update.. thanks to Shannon Whelan for coming down the last few months tinkering on the wiring... we got it running... sdaly an idiot (me) messed something up when hard wiring.. so now nada... grrr
    my daughter is just a little excited as she got first ride as promised for all her help... the wheels were rubbing as I hadnt adjusted it since building the suspension and installing.. it is now sitting about an inch above the tires till we are ready to drive for reals...
    my tuner says that my current setup should be good for around 400-415 whp... need larger injectors and another pump if I go for more.. but in a 2500pd car.. itll be fun
    minnesotanice likes this.
  3. tangledupinblu
    MNBugeyeMafia#001
    Meh, that’s pretty minimal rubbing IMO.:D
    TSTRBOY2004 likes this.
  4. TSTRBOY2004
    only a little more than at a high school dance ;)
  5. tangledupinblu
    MNBugeyeMafia#001
    Maybe at your high school.:p
  6. TSTRBOY2004
    also didnt feel like paying $140 per bracket for seat mounts.. so I designed and made my own.. still have to cut the passenger side but it has some funky mounting locations...
  7. TSTRBOY2004
  8. TSTRBOY2004
    decided to go ahead and take a chance on the changes I had made to the design of the drivers mount.. tape measure measurements and guesses on the changes and voila... almost sits flat.. it is about an inch higher on the passenger side once seat is on the mount.. tonight I should finish up welding the seat to the mount...
    Ctracey218 and tangledupinblu like this.
  9. TSTRBOY2004
    after some work being done over the last week or so I got to my doors and discovered my ds door was bent... didnt want to spend $100+ on a tool for pulling dents so I used some bolts, some heat and a vice grip haha.. minimal bondo used despite what it appears... it has to be sanded down yet
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  10. TSTRBOY2004
  11. TSTRBOY2004
    How the dented door worked out
    [​IMG] [​IMG]
    Was lazy and didnt bother fixing the lower left front guard.. until the primer went on I didnt think it would show that much.. um yeah so
    but I fixed it
    [​IMG] [​IMG]
    top pic is factory untouched door... bottom pic is my repaired door
    joebush44 and tangledupinblu like this.
  12. TSTRBOY2004
    rear corner was a little messy so I spent some more time and sharpened it up...
    before
    After
  13. MidnightImpreza
    Mounds View, MN
    Great progress! We'll done!
    silver03 likes this.
  14. tangledupinblu
    MNBugeyeMafia#001
    What’s the final color going to be? Or is that silver and not primer in the last pic? Potato camera.
  15. TSTRBOY2004
    same as the engine bay in previous photos... called Tahiti Green[​IMG]
    it was probably the upload?? pretty sure its taken with the iphone 7 plus so it aint a potato camera hahaha
  16. tangledupinblu
    MNBugeyeMafia#001
    iPhone 7+? That is the old model. Spud.:p
  17. TSTRBOY2004
    while that is true it is still a great camera.. they havent improved things that much
  18. tangledupinblu
    MNBugeyeMafia#001
    It is a great camera. Pretty sure that it’s just my old man eyes.:p Looking forward to seeing it with color on it!
  19. TSTRBOY2004
    nah it is the picture I took.. I was standing way back leaving the shop and zoomed in instead of getting closer haha
    welcome to drop down anytime.. you know that
  20. TSTRBOY2004
    Ending the weekend on a good note...
    [​IMG] [​IMG] [​IMG] [​IMG]
    [​IMG] [​IMG]
  21. pillboy
    Saint Cloud
    Looks like an original Hot Wheels Spectraflame color.
  22. TSTRBOY2004
    its actually a factory color from a Holden Barina, in Australia it turns out hahaha
    pillboy likes this.
  23. TSTRBOY2004
    Assembly time
  24. TSTRBOY2004
    updated.. got it half polished
  25. TSTRBOY2004
    designing some side marker covers
    desired effect if it works
    02subbieRS and tangledupinblu like this.
  26. TSTRBOY2004
    started milling my side marker cover plates..
    Chux and tangledupinblu like this.
  27. tangledupinblu
    MNBugeyeMafia#001
    Sweet!
  28. TSTRBOY2004
    badges on.. we tried to paint the engraving etc.. maybe eventually I will have them powder coated and retry but 2 attempts were unsuccessful.. oh well also installed the door cards I purchased over a yr ago and hadnt unboxed.. glad they are decent shape..
    Chux, predavore and tangledupinblu like this.
  29. jubella2
    jubella2 GC8 FTW
    SLP
    Great progress!
  30. TSTRBOY2004
    finally got to put her outside in the sun...
    My oldest girl now 13 (#2 of 4) has her eyes set on my car... haha she has helped me the most so she is on the list to get it if I die (like she claimed to her siblings) and Im now on the hunt for one for her to play on... IMG_4805.jpg
  31. pillboy
    Saint Cloud
    Sleep with one eye open...
  32. TSTRBOY2004
    Havent updated much as well.. it hasnt changed.. but I am datalogging and stuff.. though on saturday while datalogging we came back to house and as I pulled up to shop I lost the clutch... seems like it may be the clutch master cylinder.. Im assuming being almost 33yrs old and having sat 14yrs dry it gave up the ghost with use... everything in the clutch/bearing inside bellhousing is connected (replaced the basket ring that holds the bearing to the clutch - pull type system) but pedal stays on floor while bleeding clutch.... so hopefully wednesday Ill have the new one changed in and can start logging under some boost... so far the thing scoots with no boost
  33. TSTRBOY2004
  34. TSTRBOY2004
    clutch fixed... motor goes boom
  35. Chux
    Independence, MN
  36. tangledupinblu
    MNBugeyeMafia#001
    Ah man, that sucks!
    retreif likes this.
  37. TSTRBOY2004
    yes.. yes it does hahaha
    time to sell off all the dirtbikes...
  38. TSTRBOY2004
  39. TSTRBOY2004
  40. retreif
    Somerset, WI
    ^ None of those work for me.
  41. TSTRBOY2004
    yeah seems google pics doesnt like sharing or something..
  42. TSTRBOY2004
    well I ran my motor down to Kevin Baltz this weekend.. what a drive.. 13.5hrs each way...
    I left at 1230 friday lunch, got down there at 230am saturday, grabbed a room and slept 6 hrs, woke up showered got dressed and went to meet Kevin.. spent an hr or so hanging out discussing the engine build and other things... then got to ride in his repu.. F%^$^%g beast... then he led me out to the highway and showed the rx7 off a little... then I left towards home, stoppd for a 25min nap, then met a buddy in Kansas City for some dinner which tool 1.5hrs, then back on the road.. stopped at 3am and took a 25min nap then when the alarm went off I reset it again.. haha I was beat.. 2hrs left till home so I finished it up and got home around 5am.. slept till midday.. what a weekend.. pretty excited for my engine to be built and what it will be like..
    Repu
    FD
    Eazy_E_Rich and minnesotanice like this.
  43. tangledupinblu
    MNBugeyeMafia#001
    See ya!!!
  44. TSTRBOY2004
    motor rebuilt.. another 27 hr drive this weekend to go get it
    Leonnosyt and tangledupinblu like this.
  45. TSTRBOY2004
    new motor is in.. put some miles on it yesterday and had some fuel issues... seems an injector may have clogged (just paid to clean them) so new upgraded injectors ordered, new 10micron filter and fittings ordered.. hope to have it installed next week as I have my first car show on the 14th... back to the 80s in Burnsville.. come check it out
    MidnightImpreza likes this.
