Finally got the Project car moving forward...
Discussion in 'Off-Topic' started by TSTRBOY2004, Mar 2, 2017.
  1. TSTRBOY2004
    here are some recent pics... had to make some modifications to my exhaust manifold to try to fight boost creep, and modified my 2nd tank for a combination swirl pot/drop tank style setup.. it can drain the tank in 15 mins (16 gallons) and leaves less than a paint can lid in it... yay
    also my 15yr old bought his first car this week.. thanks to Predavore...
    EricS, Cotts612, Bugeyejake and 4 others like this.
  2. tangledupinblu
    Better buy him some 19’s for that Fozzy mate!:D
    Chux and TSTRBOY2004 like this.
  3. TSTRBOY2004
    I should email the people that bought mine.. haha loved those rims
  4. predavore
    predavore Well-Known Member
    I miss that car...
    TSTRBOY2004 likes this.
  5. TSTRBOY2004
    made the car show.. now putting miles on the car
  6. TSTRBOY2004
    about 90-95% done...
    still needs tint, and stereo/alarm.. and the tuning finished off
    BroCo, silver03, thebionicman and 3 others like this.
  7. Chux
    heh heh. You said, "done"
    Seriously, though. Looks amazing. I was hoping to make it to Back to the '80s, but ended up living vicariously through the pictures, and I saw many of your car.
  8. tangledupinblu
  9. TSTRBOY2004
  10. tangledupinblu
  11. TSTRBOY2004
    she did ask what all the noise was in the shop.. haha
  12. TSTRBOY2004
    havetn done much since it was running last summer.. but winter and now am starting to do some things again.. next up..
    Ford 8.8 mods - shorten and make custom brackets
    71142480_10156776949137921_6640843437681672192_o.jpg 83037430_10157135592287921_8324976564861140992_o.jpg 83060273_10157135592557921_7502593806324203520_o.jpg 83085460_10157135593007921_3205900899838853120_o.jpg 83775199_10157135593292921_26151965671030784_o.jpg 71949489_10156817252797921_8871318966375546880_o.jpg 71049749_10156796422442921_8530943559786823680_o.jpg 73546652_10156876388182921_6900084373723283456_o.jpg
  13. TSTRBOY2004
    Got the rear end welded up... I may stay late and cut out some of my brackets tonight although I cant fit till I have the car up on the lift and stock rear out.. which I dont plan on doing till it blows haha
  14. dipp
    dipp Well-Known Member
  15. TSTRBOY2004
    thanks haha built my own exhaust as usual...
  16. TSTRBOY2004
    little update..
    Well saturday started on a crap note.. heading to my sons soccer game with plans to hit the dyno after for 3 pulls for $30... 5miles from home pulling a 3rd gear log and lost the clutch pedal for the 3rd time in 3 weeks.. had just replaced the throwout bearing and little clutch ring/cage.. raced home after soccer and fixed the clutch... little over an hr to pull the little ring etc, straighten and fix, fix a starter bolt that stripped, put it all together, screw in a bolt in place of the clutch pedal stop... I think the clutch was over pushing so stopping the pedal travel may have fixed it.. thanks again @kevin_btz for problem solving across country.. hit the dyno after a quick little sprint 40miles to event.. ended up with 412hp 385tq on a mustang dyno.. low boost as the diaphragm is leaking on wastegate and didnt log so not sure what boost.. going from previous logs it dropped to 14-16psi... aiming for 20 or maybe 25psi.. and the car made it home.. yay
    EricS, Cotts612, Chux and 4 others like this.
  17. Cotts612
    Cotts612 Well-Known Member
    I saw flames a couple times :bounce:
  18. tangledupinblu
    I was expecting moar! Haha
    Cotts612 likes this.
  19. TSTRBOY2004
    me to tbh.. although what it means s the tune is on point and not pissing fuel down the exhaust ;)
    EricS, tangledupinblu and Cotts612 like this.
  20. tangledupinblu
    Over rated. Hahaha!
    Ctracey218 and TSTRBOY2004 like this.
  21. TSTRBOY2004
    well you saw the precious flames haha
  22. Nic Wiederhold
    Nic Wiederhold Member
    Cool project, man. I've actually got an '85 GLS-SE in storage that I've been planning a build for a couple years. Your story is pretty inspiring.
  23. TSTRBOY2004
    nice..if youre on FB come join us at Minnesota Rotary Owners club.. make sure you answer the questions...
    ***update.. project is getting cornered.. had a power surge and blew a bunch of things, gauges, LEDs, Head Unit and ECU... so till I can round up $3500 roughly to fix it all.. its parked
    Nic Wiederhold likes this.
  24. TSTRBOY2004
    nothing new.. pulled the harness, sent it to my engine builder... waiting on him... in the meantime I drove to OK and picked this up.. now to get used to total new cad and cam software than I use daily at work...
    first up tried to mill a scale mazda.... messed up something.. think I had the wrong offsets for tool or something...
    https://www.instagram.com/p/CLLBQfjHc53/
    then tried some engraving...
    then have been attempting a keyring for fun
    https://www.instagram.com/p/CLSj2EPH97M/
    147684709_10158257582927921_1140930859528685636_o.jpg 146127279_10158257582657921_6136341044666767173_o.jpg 146931472_10158257581927921_9212585567094628548_o.jpg
  25. tangledupinblu
    Nice!
  26. TSTRBOY2004
  27. tangledupinblu
    That first run was a pretty clean like brotha! She seams like she is running pretty smooth. With plenty of bite when you crack the throttle!
    Any tire rubbing at all?
  28. TSTRBOY2004
    only rubs under big bumps in the rear.. no rub in the front surprisingly... that first run was actually my 2nd run only ever.. hahaha my 3rd I went hard but clipped a damn cone... it was tough figuring the boost/powerband spot... 1st gear wasnt enough headroom, 2nd kinda bogged a little... so it was a clutch flicking type drive.. hahaha
  29. TSTRBOY2004
    its tuned correctly :)
    now moved onto daughters car
  30. tangledupinblu
    No way!? More burnout videos...please
  31. TSTRBOY2004
    I dont do those
