Anyone have fitment issues with the Perrin down pipe? It's like 3cm away from the Transmission crossmember. Took it for a test drive and any bump it bangs the crossmember. Tried all i could to change the exhaust alignment to make more room no luck. I think my only option is to take a grinder to the cross member.
Do you have it bolted to the bracket off of the tranny? If it is, then it shouldn't be moving an inch and a half...
Stock exhaust hangers? The extended ones help quite a bit...not sure if they'll help that far up the system tho. Maybe mark the downpipe where it makes contact, remove, and bang on the DP with a "BFH" to make a little more clearance?
I'm using Kartboy standard length hangars. I ended up taking them off and removing the down pipe. Ground down the crossmember a little bit with an angle grinder then put it all back together. I needed to bend the down pipe support bracket a little bit but it's all together now. All i can say is that i love Stage 2!!
