Fittings Q's
Discussion in 'Modifications And Maintenance' started by Bielke55, Oct 2, 2008.
  1. Bielke55
    Does anyone know how the AN Measurment system works?
    Also if i want to run a SS line from my block where it once was rubber and nipple how can i convert it?
  2. readymix
    If you want a threaded mount, you would probably have to remove the nipple, then drill and tap a hole in its place. Then thread in an A/N fitting.
  3. readymix
    Otherwise, I've seen AN 'look' sleeves that you put over the hose clamp.
  4. Bielke55
    How do i know what A/N to use though? Is there a way to convert Inchs or MM to what A/N equals?
  5. readymix
    The AN size is just the hose size, the fittings that thread in should be NPT sizes.
  6. Bielke55
    So how does it work?
    A hose thats -10 A/N is what in inches(or MM)?
  7. Threshld1
    Threshld1 Well-Known Member
  8. Bielke55
    Awesome thank you!
