Fluid recommendations
Discussion in 'Modifications And Maintenance' started by Paul Revere, Nov 15, 2008.
  1. Paul Revere
    So I want to change my trans and rear diff soon, as of right now I believe there is Redline in the rear diff and I put Scotty's in the trans this summer. What do you guys suggest for the trans and rear diff? What weights and brands.
    Chet
  2. 02blubru
  3. Paul Revere
    Sweet! Thanks Bill I recall that thread but couldn't find. Looks like the cocktail it is then.
    Next up what weight and brand for the rear diff?
  4. 02blubru
    I was using amsoil OE weight in the rear diff. never had an issue. but nate used the same and seems to think it is what caused his rear diff to fail.
  5. TSTRBOY2004
    I used synthetic and dont know if it was the amsoil though... but yeah.. 75w90 weight in the rear I believe
  6. John16V
    John16V Well-Known Member
  7. AWDimprezaL
    I would stick to something normal, Not the coctail, its scary.
  8. TSTRBOY2004
    amen...
  9. Paul Revere
    Maybe Motul?? They make great stuff!
  10. AWDimprezaL
    really, just get some normal 75-90, probably not even syn.
  11. Paul Revere
    ^I will do this. So the trans gets the same thing as the rear diff?
  12. AWDimprezaL
    nope, rear gets 80w-90
  13. Paul Revere
    Thank you Erik!
  14. Paul Revere
    Non-synthetic in the rear?
  15. AWDimprezaL
    you can run syn in either one, I dont find it really needed though.
  16. Rexwagon
    Rexwagon Well-Known Member
    I prefer royal purple, amsoil severe gear or eneos 75 90
  17. TSTRBOY2004
    IMO synth is tooooo thin for gears.. but hey.. $1000 later what do I know
  18. 02blubru
    you know that your rear diff failed and it cost you 1000 to replace it. lol
  19. AspitFire
    i would stay away from the "cocktail" worked great for a while (6 months), but now its terrible.
  20. Shibbs
    I ran it in mine and it definitely helped the synchros to bind better, but now I'm back to full syn and I notice no difference between now and when I was running the coctail.
  21. 02blubru
    I ran the cocktail in my wrx, but it will NOT be going into my forester.
  22. Kracka
    Kracka Member
    Use whats included in these kits: http://www.redlineoil.com/products_powerpacks.asp?productID=56&subCategoryID=19
    Redline is the best transmission fluid I've found yet. I've used it in a lot of cars with great results. I've also tried/tested a lot of others and have yet to find one I like as much. Stay away from Royal Purple products; that stuff is junk. Its fine initially, but it wears out so much quicker than anything else (the additive packages deteriorate) its ridiculous.
  23. prezawagon
    prezawagon Well-Known Member
    Yep, I'm noticing the same thing. Scotty's worked great at first, then has consistently gotten worse. I'm going back to plain ol' valvoline.
