Flutter noise
Discussion in 'Modifications And Maintenance' started by WilliamSTian, Mar 25, 2011.
  1. WilliamSTian
    WilliamSTian Active Member
    I just started noticing a metal fluttering sound that comes and goes. It went on for about fifteen minutes while I was driving today. It sounds like it's coming from the passenger side heat vent. It was happening all the time but mostly
    Only when Moving, and I noticed it didn't matter if taken out of gear or in gear, the noise was just constant. Any ideas? Thanks.
    2006 STI
    TBE
    CAI
    GSbcs
  2. blackozone
    Was it a very rapid ticking sound?
  3. WilliamSTian
    Yeah, it did sound like that
  4. project/driven
    Possibly a loose wastegate arm causing the wastegate to rattle in its seat. See if you can hear a similar sound when moving the arm, or even if it seems to move much at all it could probably be tightened.
  5. blackozone
    Does your BCS have a rubber grommet between itself and the mounting point on your strut tower?
  6. WilliamSTian
    It has a rubber washer between where it's tightened if that's what you mean. I was also reading up on the BCS noise, but why would it just start making that noise after 9 months without? I did notice it was a Little loose and could use tightening.
  7. project/driven
    Can you manipulate it back and forth and get it to make any thing close to the same noise?
  8. idget
    When you reused the rubber grommet did you also reuse the metal inner sleeve?
    I would check the bcs, uppipe/exhaust manifold for a leak, and the wastegate (for flutter). Who is your tuner? Maybe they could take a look and listen?
  9. WilliamSTian
    I tightened it and I'm going to see if that noise went away. I'll let you guys know, thanks for the help
  10. WilliamSTian
    Tuned by Nate. It sounded like some type of fan mechanism struggling and causing a metal
    On metal sound is what I thought, but it could have been loosely tightened BCS, I'll let you guys know asap
  11. Nuke
    If the sound is only there on cold mornings or such, probably bcs
  12. Bullwinkle
    If it sounds like a mini helicopter coming from your turbo area and occurs loudest during mid/partial boost (0-5 PSI) it's wastegate flutter or the BCS clicking.
    BCS clicking can be mitigated by a grommet between the BCS and mount point, WG flutter is perfectly normal nothing to worry about.
