FMIC Install Q
Discussion in 'Modifications And Maintenance' started by ej20, Apr 19, 2009.
  1. ej20
    ej20 Well-Known Member
    02WRx.
    ok so I'll be putting in a FMIC soon. The thing I kept trying to figure out is the piping to the turbo and throttle body. Ok, the 2 IC pipe that ran back into the turbo and throttle body, does it matter which side of pipe goes where(turbo or throttle). I know they're different in diameter each side. I've seen setups where the driver side IC piping goes to the turbo AND some to the throttle body. So does it matter? Does it depend on my IC piping?
    Mine is CXRacing FMIC.
  2. Iroc-Z
    Iroc-Z Well-Known Member
    It will only fit one way. I have seen some people switch the pipes around on Nasioc but they had to add pipe. The pipe that goes from the passenger fender goes to the TB.
  3. ej20
    I mostly see the passenger side go to the turbo.
  4. Kevin
    Kevin Well-Known Member
    thats how mine is, it is a smaller diameter pipe and it has a 180 bend in it.
  5. Iroc-Z
    Hmm weird. I guess mine is different
  6. Nuke
    The SSAC kit that we installed, you can install it either way
  7. GarageAlchemist
    GarageAlchemist Member
    pics would help here i think.
  8. ej20
    Does it matter? its still gonna circulate.
  9. Nuke
    didn't matter, still worked
  10. Iroc-Z
    The bov pipe should be the one that goes to the throttle body.
