Forester overheats when A/C is running
Discussion in 'Modifications And Maintenance' started by qstarin, Jun 25, 2009.
  1. qstarin
    qstarin Well-Known Member
    Uptown Mpls
    98 Forester, 4eat.
    Car's temp rises beyond normal when the A/C is on until we turn the A/C off. We figure if we didn't turn it off it would keep getting hotter (i.e., it doesn't plateau). Been doing it for a couple weeks. Does it both in town and on the highway. Both radiator fans work. Coolant level looks normal.
    Car has never had an issue with overheating since we've had it, except when we towed a heavy load (to be expected).
    What should I check? Thanks in advance.
  2. Ryan
    Ryan Sled drifting master
    I'm also interested in this for my co-worker who has a '02 outback sport. Same situation, not sure on his coolant levels yet, but I'll know by tomorrow.
  3. AWDimprezaL
    Monticello.
    I'll say it again...head gaskets, its a 1998 its not an "if" they will blow, its "when".....PM driftin240 or subytek, maybe they can do a bit of diagnosing in thier free time.
  4. john
    john Well-Known Member
    Hudson
    Have you burped the coolant system more than once? If so, I'd agree with ^^ with regard to a possible head gasket issue. Any oil in the coolant or vice versa?
  5. qstarin
    Uptown Mpls
    So, speculating, if it is the head gasket - why does it only overheat with the A/C on?
  6. AWDimprezaL
    Monticello.
    its probably in the early phazes of it, the extra work the compressor puts on the engine is enough to make it overheat. Get a coolant fill bucket (one that sits on top of the rad cap opening) fill it about 1/4 of the way up, start the car, look for a constant stream of bubbles coming up, expecially around the times when the fans come on.
  7. kvang
    kvang Well-Known Member
    St. Paul
    Have this issue with older vehicles that come into our shop. You could also check for debris stuck in front of the condensor or bent condensor fins. If there is, wash the condensor off and blow off with a blow gun.
    Then go from there. If you are still overheating you could get a coolant funnel and top off the coolant with the funnel and then start the vehicle and watch the coolant level if it rises or lowers or bubbles.
  8. Dirtywagon
    Dirtywagon Member
    Bloomington
    See if both your fans are running when your a/c is on
  9. hex2bit
    hex2bit Well-Known Member
    Rochester, MN
    My brother had his car start running hot when his fans stopped running (blown fuse). With AC on, the fans will always run, so it's an easy thing to check. With his car, it was far more noticeable when running AC. With AC off, it would keep up unless you were putting around town.
  10. qstarin
    Uptown Mpls
    Fans run, fins are clear. Its doing it often just driving now, too, but kinda randomly. Fk I don't wanna do HG's on this car. Guess I should maybe swap the thermostat in case that's acting funny.
    Anyone know if there's an updated HG for this engine?
  11. AWDimprezaL
    Monticello.
    yes they are updated. And yes they are blown, sorry to burst your bubble man, its not ever IF, its WHEN with DOHCs.
  12. Kosh
    Kosh Well-Known Member
    Could try adding some "Subaru Conditioner". AKA Stop Leak. Don't go to the dealer, they will tell you $2000. Someone on the forums should be able to get you a good deal.
  13. AWDimprezaL
    Monticello.
    No, thats only for EXTERNAL leaks, external leaks DO NOT cause over-heating, UNLESS you let them leak out all the coolant.
    pcwerk likes this.
  14. qstarin
    Uptown Mpls
    Like AWD said, that's for the one's that are seeping out coolant, and even then I distrust any sort of stop leak. If it can clog up a leak, it could clog up other things, imo.
    And it'll be a DIY, maybe with assistance. Not paying labor when I already got the vast majority of the tools I need (incl. engine hoist) - just a little short on space and motivation.
  15. strangefamous
    MN Bugeye Mafia #002
    Beer = motivation. :yumyum:
  16. carl
    we gotta gooooo
    pretty sure that's backward - I do less work while drinking beer :laugh:
  17. AWDimprezaL
    Monticello.
    Indeed that is def the case, or at least I get more injured!
  18. strangefamous
    Yeah hahaha. All too true.
