Front axel question
Discussion in 'Modifications And Maintenance' started by scrltspedstr, Feb 2, 2014.
  1. scrltspedstr
    scrltspedstr Well-Known Member
    so i need new front axels on my 04 wrx
    I have been told most refurbs are garbage and i cant seem to find a pair of good used ones.
    where should i buy from?
  2. Medic_538
    Medic_538 Well-Known Member
    stock power = stock axle.
    You get what you pay for.
  3. jdhunter6
    jdhunter6 Member
    I have used autozone with no problems.
  4. Peder
    Peder Well-Known Member
    Check with Minnetonka subaru. I believe you can get rebuilt stock axles through them. And you can use your club discount.
  5. yuseforester
    A-1 Cardone ranufactured axles are pretty good, this is the only brand I would use other than nee oem, have had no problems with these on a stock or lightly modified car.
  6. xluben
    Are they the same as an 02 WRX? I have one available.
  7. silver03
    I have had no issues with NAPA rebuilds.
  8. Fatboy Walrus
    Fatboy Walrus Well-Known Member
    I've had issues with remans from orielly. 2 bad remans in a year.
  9. spudd
    spudd Well-Known Member
    Are the boots just torn? You can get new boots, clamps and grease from subaru. We reboot them all the time
  10. Ryan FailRad
    I just did a re-boot last night, not hard at all. 20$ fix for me, what would you guys charge for this?
  11. spudd
    Right around $300 parts and labor
  12. scrltspedstr
    the grind a bit when its realllly cold and make sharp turns
  13. scrltspedstr
    just to double check
    i have a male axle and a female transmission
  14. Deride
    Looks like there is a spring pin in there, so female axle inner male outer. Would be the same as an 2002
  15. iand464
    iand464 Well-Known Member
    I might have some used 02 axles in my garage or shed. Pm if interested
  16. xluben
    No, that is backwards.
    Correct.
    I have used 02 axles sitting around as well.
