frozen intercooler tank
Discussion in 'Modifications And Maintenance' started by Gridlocked, Dec 15, 2008.
  1. Gridlocked
    Alright, flame suit is on.
    I don't even own a car with the intercooler sprayer, but what if the tank is full of water and the thing freezes solid? I only found one thread with some information, and one said leave it half full and let it freeze, the other said to leave it a quarter full and let it freeze.
    What do you STi owners do and has anyone run into problems?
  2. curly2k3
    i would assume just leave it quarter-half full and let it freeze, seeing as you don't need it in winter. lol
  3. Gridlocked
    :laugh: this is true, but I was considering the water in the pump and lines expanding.
  4. Moleness
    Hmm, I wonder how full mine is :ugh: I barely use it anyways.
  5. wrexinator03
    wrexinator03 Banana Cream
    well either way there will be some sort of water left in the lines and pump i'd assume....so i dont think it really matters?!?!
  6. Gridlocked
    That is what I figured, but I didn't know and didn't see any info on it. I met freeskierwi tonight and he asked so my curiosity got the best of me. His is pretty much full and frozen solid. I told him to put some salt in there to thaw the water and then wash it out with windshield washer fluid, but I was guessing. I'll make sure he doesn't do that. it seemed like a good idea at the time.
  7. curly2k3
    i guess i wouldn't worry about it too much. if its not over filled and there is room for it to move around i would assume it wouldn't cause damage.
  8. wall of tvs
    fill it full of washer fluid
  9. wrexinator03
    yeah i'd assume even if ran empty there would be water in there so i think it doesn't really matter...other subaru wasn't thinking very well on this one
  10. TSTRBOY2004
    exactly what I was thinking... besides... in summer the alcohol content is better for cooling.. ever spilled that stuff on yourself and felt it evaporate
  11. Soupboy
    Soupboy Well-Known Member
    Every night right before making romantic explosion.
  12. TSTRBOY2004
    gotta cooly down a cock
  13. subytek
    subytek Well-Known Member
    I believe the owners manual says make sure it is half full or less, but not sure.
  14. Soupboy
    Be gentle as to avoid chafing.;)
  15. carl
    mine is full of washer fluid... because it's been converted to my washer resevoir
  16. NMDAYTIME
    NMDAYTIME Well-Known Member
    the first thing i did when i bought my car was put washer fluid in it. i kind of like the blue stained tank in my trunk... WAIT!
  17. aspiringRexer
    aspiringRexer Member
    This quasi-sentence is amazing.
  18. austinpike
    austinpike Well-Known Member
    You could find an underground ramp to park it in to thaw - downtown Target is nice and if you spend $20 in the store you get free parking - then mix in a bit of rubbing alcohol. There was some argument for not using washer fluid, but I can't recall exactly, it wasn't anything big so that would probably work too. Could it stain the IC? I dunno.
    At any rate, mine froze a couple winters, the lines never burst or anything, it really isn't anything to worry about. The only annoying thing is when it partially thaws, and you have a huge ice cube floating around clunking in the tank.
  19. Andyman8662
    Andyman8662 New Member
    step 1: drive to wisconson
    step 2: buy everclear
    step 3: profit?
  20. Dream
    I dont think I ever used my i/c sprayer when I had my STi.
  21. TSTRBOY2004
    its out of a kevin Bloody Wilson song...
  22. idget
    Yeah, the owners manual has a piece about leaving it half (or less) full over winter.
    +1, let it thaw out, drain it down to half or less then leave it alone. I just drain mine most of the way since I'd go crazy hearing a partially thawed block of ice clunking around in the trunk on warmer days.
    I think the arguments for not using washer fluid and alcohol is their decreased capacity to dissipate heat compared to water and of course the mess factor.
  23. webcrawlr
    webcrawlr Well-Known Member
    Follow the manual (1/2 full) and you'll be fine. How many threads have you seen with IC sprayer issues after it freezes? ;) There's more then enough room for the water to expand.
  24. Skarecrow
    Skarecrow Well-Known Member
    this!!!!!!!!!
  25. M155L3R
    M155L3R Well-Known Member
    i put isopropyl alcohol in mine for the 1/4 of the winter that i drove it but now i store it for the winter
  26. Chin
    Chin Well-Known Member
    I haven't touched it in any winter (on its 6th winter, now) other than making sure it is <3/4 full.
  27. Tim the Plumber
    the main thing is if your running water in it dont use it in the winter... pump will burn out but i like Andyman's idea... just hold a shot glass under your hood and your good to go
