FS; GC Parts Request Thread
Discussion in 'For Sale : Car Parts' started by 95lwrx, Nov 18, 2006.
  1. k_thaosta
    k_thaosta Well-Known Member
    Could you get a few pictures of it, maybe it can be determined that way...
  2. 95lwrx
    95lwrx Well-Known Member
    i can try, i don't have a good camera right now, so the pics won't be the best. but i'll try to get some today.
  3. AWDimprezaL
    Got that peice for around the radio and shifter for a MT?
  4. 95lwrx
    nope, im short on those, since most of my damn cars started out as autos
  5. 95lwrx
    alright, my cameras screwed up so i cant get any pictures, maybe you could talk to erik or one of the guys at tonka to check on their parts lists
  6. Yang
    Yang Well-Known Member
    I need the two metal plates that joins the radio with the din. got any? Its basically the mounting bracket for the stereo to the dash.
  7. AWDimprezaL
    ps pump is not the same
  8. 95lwrx
    nope, none of those.
    and erik thanks for checking on the pump.
  9. prezawagon
    prezawagon Well-Known Member
    How about that small spring that's on the clutch fork, located below the airbox? I noticed today that mine's missing... must have broken or something, I know it used to be there.
    Thanks.
  10. 95lwrx
    nope, the one extra one i had i used since one of my cars was missing it.
  11. hakstern
    hakstern Member
    Hey,
    I was wondering if you have the MAT (don't know what it is called, sorry.) under the HOOD. Also do you have the hood scoop+Hood Vent like bottom hood cover (it's to prevent water/snow getting in I believe.)? (Don't know what it is called also.) The mat under hood and Hood vent + hood scoop under the hood cover is what I'm looking for.
  12. 95lwrx
    i don't have the heat shield pad or mat thing, that's the first thing i get rid of on my cars, just don't like them,. i don't have a spare scoop but i have the underside cover that i could probably part with.
  13. hakstern
    hakstern Member
    Yeah I'm looking for the udnerside cover for the hood scoop and hood vents. If u have PM me please. Thanks
    -Bryan
  14. vr6t3t4
    vr6t3t4 New Member
    knuckel
    i need the rear wheel nuckle or hub mount thing whatever you call it do you have that?
    and some 16" wheels
  15. curly2k3
    hey, um just thinking about this, why not borrow a camera or have someone just take pics of the parts you have or are willing to part with
  16. 95lwrx
    ha playing in the snow were we :biggrin: i do have both rear assemblies but they came from a car with drum brakes so you would have to either press the outer part of the hub off or cut off the backing plate for the drum brakes. the hub part itself is the same but you would need to use your backing plate from the disc brakes.
    i don't have any 16'' wheels though.
  17. 95lwrx
    well i can take pics with my video camera but they just are kinda fuzzy and not a good quality picture.
  18. vr6t3t4
    vr6t3t4 New Member
    would they work if i did that? how hard is that to do and what do you want for 1 of them?
  19. 95lwrx
    well the easiest would be to press the outer piece off and remove the plate, and depending on how the backing plate is on your car i know on some you do not need to remove the outer part the plate just unbolts off. but if you press it off you risk screwing up the bearing. i wouldn't need too much for it. i could press the thing apart at work to get the plate off of there.
