Just bought my 04 WRX planning on switching to e85, I know their are alot of options for fuel pumps and diffrent ways you can do the injectors. I was planing on picking up some bosch 1000cc injectors, so I guess im just trying to figure out what size pump i need. any advice would be great thanks guys.
walbro 255 are good the new bigger walbro isnt good. but depending the turbo your running a single 255 should be just fine.
Talk to your tuner. If you don't have a tuner yet we have a bunch of local tuners. I would suggest NF Performance. They can help you figure out your goal for your car. That will make it easier to figure out what parts you want to buy. As well I hear that one of them is pretty handy with that corn juice stuff I have been working with NF for a while now, and I am ALWAYS 100% satisfied with the work they do and advice they give.
Dunno who the heck are these NF Performance guys but forget them any of those bosch 1000's and a walbro will work fine for you.
Not timing, valve clearance (i knew someone would comment on that). Exaust valve on cylynder 3 had tightend up. tore off the head measured for proper clearance and installed a diffrent shim. valve seat wasnt damaged so i didnt have to send the head out (thank god). Also replaced the timing belt while i was at it. and the new leak down and compression test showed prime results.
